Is there a 39 or 40 tooth...
Old Nov 25, 2006 | 09:33 AM
Scott V's Avatar
Default Is there a 39 or 40 tooth...
sprocket available?
My bike is setup for the street and I wanted to gear it up a bit. I have a 41 tooth with my 17 inch rims
and it turns a few more rpm then I want on the freeway.
It pretty smooth with the street tires/ aluminum bars/ gel type grips.
I also added these Suzuki DRZ400-SM inserts to my foot pegs.
I am making a great little street bike out of this thing. Although I
can still swap back the off-road stuff in about 1 hour.
[IMG]local://upfiles/3498/3A16F58C63264E0684D35C4BB7EA3124.jpg[/IMG]
Old Nov 25, 2006 | 09:58 AM
tremor38's Avatar
Default RE: Is there a 39 or 40 tooth...
Contact Maverick Aus and see if he might be willing to part with the 39 tooth rear that he's presently not using. You will need a shorter chain though. I have a D-tracker and the 14/39 combo works perfectly for the street...not to mention the smaller rims.
ORIGINAL: Scott V
sprocket available?
Old Nov 25, 2006 | 02:50 PM
MaverickAus's Avatar
its yours if you want it, prob cheaper to get it over there tho, than pay for freight from aus, yeah and you will need a shorter chain
Old Nov 25, 2006 | 04:40 PM
Scott V's Avatar
I would like to try to find it in the states first because of the shipping issues$$$$$. Thanks for the offer
and I will keep it in mind if nothing can be found.
Scott
PS-a pic. of the license plate light you wanted. Still hard to get a good look at it.
[IMG]local://upfiles/3498/926B3E18937E4628BFA304389ACD83E4.jpg[/IMG]
Old Nov 25, 2006 | 06:47 PM
tremor38's Avatar
http://www.parts411.com/acb/showdetl...TOKEN=84980641
Check out the above link. It says the item is available all the way down to 38 teeth. You just have to specify the size in the box provided. I'm not sure what material Sprocket Specialists use though. If it's aluminum you may not want it. Wouldn't hurt to give those guys a call to find out though.
ORIGINAL: Scott V
Scott
Old Nov 25, 2006 | 07:04 PM
Scott V's Avatar
I am fine with aluminum, as long as it's a decent grade.
Thanks for the link!!!!
Scott
Old Nov 25, 2006 | 10:04 PM
Thanks for the pic scott, it shows how bright the LEDs are which is all I wanted to see
cheers
Pontiacdude210
Classic Sportbikes
Dec 27, 2011 02:48 PM
JasonFMX
Sep 28, 2008 03:11 AM
07 KLXER
Jun 12, 2008 12:14 AM
Aug 30, 2006 12:37 AM
Zx9s4
Aug 3, 2005 02:29 AM
