Taller bigger rider - handlebar and riser question
Old Mar 22, 2018 | 10:03 PM
RaceGass's Avatar
Sounds like you guys need taller seat foam n covers to match your new bar heights. I would see the racers like David knight and his tall seat profile
Old Mar 22, 2018 | 10:07 PM
Tacoma660's Avatar
I got the taller seat from seat concepts and i wouldnt change a think with my cockpit. I have my bars pushed a bit forward so it matches how i ride my snowmobile.
Old Mar 23, 2018 | 12:35 AM
Need-less-desk-time's Avatar
I'm probably going to go up at least 2 inches, maybe 3 and the taller bar too....
I see on motion pro's website that they have a 3 inch longer clutch cable, but nothing listed for a longer throttle cable. In fact, the throttle cables they have are listed as either stock or shorter. I have research to do.
Previous owner put on a larger gas tank aftermarket, so that might alter things too. Man, I wanted to be out and riding by now!
Advise is so welcomed!@
Matthew
Old Mar 23, 2018 | 04:41 AM
outrecording's Avatar
Matthew
With my 3 1/2” risers that 3” longer clutch cable just BARELY fit. For the throttle cables I ended up making my own. Surprisingly it wasn’t that difficult and kinda fun.
Old Mar 23, 2018 | 07:53 PM
Default Would you mind sharing how you built the throttle cable?
I'd be willing to give that a try.
Also, besides the clutch and throttle cables, did you need anything else when you brought it up by 3"?
Thanks!
Matthew
Old Mar 23, 2018 | 08:02 PM
RaceGass's Avatar
+3" wonder if the front brake line can be slacked by readjustingp the lower brake line mount on the left fork leg guard and removing the wire brake line holder by the caliper
Old Mar 23, 2018 | 10:02 PM
Tacoma660's Avatar
With a 2inch riser i have plenty of brake line left, just gotta loosen the clamp pull pull up some slack
Old Mar 27, 2018 | 02:49 AM
Thanks!
Matthew
sent ya an email and PM. Not sure if you got them.
Old Mar 30, 2018 | 06:17 PM
I sure did!
Thanks so much
Tacoma660
Mar 26, 2018 10:01 PM
D-Tracker X Brazil
Aug 27, 2010 07:00 PM
Buzztail
Feb 13, 2010 01:05 AM
SlapDrum
Dec 21, 2009 11:31 PM
bryantjt
Mar 1, 2007 02:27 PM
