Surge at 6500 rpm at highway speed
Old Feb 18, 2013 | 10:54 PM
  #171
Pogiboy's Avatar
Originally Posted by Dark Angel
I don't know if this will make any difference on the KLXs for this problem, but I like to use iridium tipped plugs. They seem to give more reliable ignition under adverse conditions on everything I've used them on.
X2 on iridium plug. Improved start hot or cold and my bike just rides better
Old Feb 19, 2013 | 03:02 AM
  #172
2veedubs's Avatar
X3 on Iridium plug, works well on KLX250.
Old Feb 19, 2013 | 03:12 AM
  #173
Brieninsac's Avatar
Sure would be a lot easier than rejetting. I'll pick one up this week. So just any iridium plug? The service manual says I need a Special Tool - Spark Plug Wrench, Hex 16: 57001-1262 to remove it. Can't I just use a long socket?
Old Feb 19, 2013 | 03:26 AM
  #174
Dark Angel's Avatar
Not just "any" iridium plug. My personal preference is NGK brand and the size and heat rating need to match what's in there already. There should be a plug tool in the tool pouch under the seat, just be gentle with it coz they're made out of the same stuff as the spanners ie case-hardened cottage cheese. Unless of course things have picked up since my last bike ... which I doubt.
Old Feb 19, 2013 | 04:53 AM
  #175
RockabillSlapMatt's Avatar
I just use a standard spark plug socket(smaller of the two) I got in my standard ratchet kit
Old Feb 19, 2013 | 09:44 PM
  #176
cujof16's Avatar
Took the bikes out today! The mod absolutely worked by grounding the blk/yel wire to the engine. Pulls solid now from start and no stmble/surge at 6500-7000 3/4 throttle like before. Smooth as could be. Both bikes run great.
Old Jun 16, 2013 | 01:20 PM
  #177
bradluke0's Avatar
Hi all ! I looked for the connector to do the ground mod and I dont see anything like that around the rectifier or around the starter . Does this mod affect the '07 KLX's ? thx again guys.....brad
Old Jun 18, 2013 | 04:29 PM
  #178
bradluke0's Avatar
Hi all ! Anyone?
Old Jun 18, 2013 | 04:58 PM
  #179
Brieninsac's Avatar
There are lots of pictures in this thread, you just need to go back further.
https://www.kawasakiforums.com/forum...e8/#post488975
Old Jun 18, 2013 | 08:15 PM
  #180
wildcard's Avatar
I don't believe anyone has reported this issue with the 06-07 bikes FWIW
