Supermoto wheels - what do I need?
Old Jul 21, 2011 | 03:34 AM
JHNguyen89's Avatar
Default Supermoto wheels - what do I need?
Hey Guys,
I just picked up some stock KLX250SF wheels on Ebay and it comes with just the rims/tubes/tires. I currently have an 09 KLX250S and plan to remove the stock rear sprocket and rotor and mount them on the new SF wheels. Will they mount up fine or would I need a new front brake kit?
Thanks!
Old Aug 2, 2011 | 08:01 AM
Trialsrider's Avatar
Hi
I fitted a set to my 09 klx a few months back used original discs and sprox just be careful removing disc bolts( there is threadlock on them and Allen head can easily get damaged. The only thing I had to do was fit a speedo healer as 17" front rim made the speedo reading way out.
Regards Alan
Old Aug 10, 2011 | 04:36 PM
DUNCANMOTO's Avatar
I did the same thing.
The sf does have a larger brake disk in the front, but you can fit the s model disk.
There is a brake spacer bracket and a larger disk that came with my wheels.
If you don't have the SF disk, or spacer, it will still fit.
ddt1972
Jan 19, 2009 04:53 AM
ddt1972
Oct 24, 2008 01:21 AM
m6thompson
Aug 14, 2008 12:32 PM
je2000
Aug 13, 2008 06:51 AM
PeaSoup
Sep 20, 2007 03:48 AM
