STOCK FORK SETTINGS WERE OFF!
Old May 10, 2006 | 04:50 PM
okiswede81's Avatar
Default RE: STOCK FORK SETTINGS WERE OFF!
screwdriver. the plugs have a flat side on them so you can get the end of a screwdriver under it and just pry it out.
Old May 14, 2006 | 05:18 PM
FM_Thumper's Avatar
Mine was 11 clicks on the right and 11.5 clicks on the left...[&:]
I set it for the factory setting of 8 clicks out. I'll go for a ride to see how it feels. Most likely since I weight about 185, probably 195 with gear, I will be stiffening it up a little more.
Old May 18, 2006 | 01:04 AM
FM_Thumper's Avatar
Huge increase in street handling with the 8 clicks instead of the 11.5 clicks that the bike came with. No more nose dive around corners and the front end is lot more stable at highway speeds. I'll go down one click at a time until I find the best compromise. My "dry weight" is 180-185 and I probably weight about 195 with helmet and gear. How many clicks out should I set it at? I ride agressive on the street. Off-road, I don't do jumps, just trail riding...
Old May 20, 2006 | 06:39 AM
konacoiler's Avatar
My "dry weight" is about 200lbs. I went with Todds fork setting of 4 clicks out, and took the shock compression damping and Rebound down 4 clicks each from the stock setting. This set up works awesome on the street. It turns and handles way better. Off road is another story altogether. I took it in some deep sand, and the front end tried it's hardest too pitch me to the ground. This set up might work good in hard pack..but in the sand it [sm=smiley11.gif][sm=smiley21.gif]
Old May 20, 2006 | 10:54 PM
konacoiler's Avatar
Hey Travis. I had a similar experience when I adjusted the forks. I turned them all the way in(clockwise), and then backed them out 8. They were initially at 11 and 12. The forks were like mush after changing them to 8. They would almost bottom out just by my pushing on them with the front brake on. I turned them all the way back in, and then backed them out to 4 clicks and they were fine. Not sure why they did that, but the less clicks out from being seated, definitely makes them firmer. Trying too find a setting that works great on and off road is nearly impossible. Firmer works better on the road, but then it doesn't allow the suspension to do it's thing off the road. Just have too find a happy medium, I guess.
Old May 21, 2006 | 05:13 AM
FM_Thumper's Avatar
ORIGINAL: Iowaguy
actually, that's the opposite of my experience. the further i seated them the mushier they got. i backed them out 15 from fully seated and they are perfect for me. does anyone know the official word on the adjusting?
Huh? That's the opposite of my KLX. Are you going clockwise looking down on the ground or clockwise looking up from the ground?
pauley2000
Jun 20, 2008 04:28 PM
srobak
Feb 1, 2007 06:55 AM
jeepphamilee
Sep 15, 2006 03:11 AM
LeftyS7
Jul 27, 2006 05:34 AM
txredneckmedic
Joke section!
Jul 2, 2006 09:43 AM
