Stock chain type?
Old Aug 11, 2009 | 11:51 PM
redpillar's Avatar
Default Stock chain type?
I was wondering if we all have the same make of o ring chain on our 09 models. I wanted to buy a spare master link or two and the kawi dealer doesn't even stock them...WTF?
Mine is an EK520 LVO ......whatever that means.
Old Aug 11, 2009 | 11:56 PM
cliffsta's Avatar
Psh, our B.S. local stealership doesn't stock ANY master linkes (420 or 520). Ridiculous.
I would think any #420 master link would work, but someone else may be able to verify that for you 100%
Old Aug 12, 2009 | 12:41 AM
WestOzKLX's Avatar
Any #520 link!
Old Aug 12, 2009 | 05:19 AM
cliffsta's Avatar
Uh oh. I think I put a #420 chain on mine when I changed sprockets and I used stock (well, Primary Drive) replacement sprockets... specifically the Honda XR650L front and the KLX250 rear. But we ordered it on dad's account so I don't remember what we ordered...
Have I effed up my shat? Wouldn't the chain have broke by now if I had the the wrong size (specifically too small?)
Old Aug 12, 2009 | 05:46 AM
redpillar's Avatar
not sure but the pitch would be different from a 520 for sure.
Old Aug 12, 2009 | 05:51 AM
redpillar's Avatar
Here is a bit of info
A motorcycle chain is the most common method used to connect and drive the rear wheel in a motorcycle. The others are belt drive and shaft drive.
Chain size is in inches, the three digit number used to discribe the chain size is based on the "rule of eights". The first digit is for chain pitch. This is the distance between the pins. The second and third digits combine for roller width, with a decimal point inserted between the second and third digits.
For example, a 420 chain has a pitch of 4/8" = 1/2" (12.70mm) and a roller width of 2.0/8" = 1/4" (6.35mm).
A 525 chain (the size my bike uses) has a pitch of 5/8" (15.88mm) and a roller width of 2.5/8" (7.94mm).
A 530 chain has a pitch of 5/8" (15.88mm) and a roller width of 3.0/8" (9.52mm).
There are a number of chain sizes in use, and chain manufacturers may have slightly different specs for roller diameter, sprocket width, etc. But a 525 chain from one manufacturer will have the same pitch as a 520, 525, 530, or 532 chain from another and run smoothly on any 525 sprocket from any manufacturer.
Old Jun 20, 2023 | 03:36 PM
DaveR's Avatar
Default EK 520 LVO Master link
Hi, I just joined the forum. I have an 07 Sherpa S . Barn find 900 km. I have just put new tires on it and picked up a 520 master link so I can remove the chain for service. BUT could not get the outside plate on far enough to attach clip. Called a Kaw dealer and he said it must be an EK 520 LVO. Which he can bring in. Apparently LVO Iis the key. $18.00 c. FYI
jazzman
Ninja 250R
Sep 26, 2006 08:30 PM
walight01
Aug 29, 2006 06:45 AM
wolffhogg
May 3, 2006 04:46 AM
aijai
ZZR 600
Feb 20, 2006 03:06 AM
ZX12Rider
Dec 5, 2005 08:45 PM
