Still having trouble with this website!!
Old Jan 23, 2010 | 01:19 AM
  #71
Odimus's Avatar
Originally Posted by dan888
Firefox must suck too then, because that is the other browser that I mentioned I am running. Honestly, Firefox does seem to do better than IE now, but it's still less than a 50/50 shot every time I click around here on KF. I had no problems with IE here or anywhere else, befor xmas now here nothing works well.
Dan
After going through all the threads here...have you tried your account on a computer outside of your house??? It sounds like an update didn't quite take...alot of the times i've seen problems with adobe flash...I would recommed use the RESTORE from a date prior to December...run it and see if there are any problems...then watch which updates start happening...make sure you set it to where it asks you if you want to update...
Old Jan 23, 2010 | 01:59 AM
  #72
redpillar's Avatar
It was just around xmas that this started. Mac is no problem.
Old Jan 23, 2010 | 02:03 AM
  #73
Odimus's Avatar
it'd probably an update from Windows that didn't take right...the security settings can be reset back to the defaults...
Old Jan 23, 2010 | 02:04 AM
  #74
Thanks for the Ideas Odimus,, I'll give it a shot this weekend.
Dan,
Old Jan 23, 2010 | 02:05 AM
  #75
redpillar's Avatar
Dan888 are you using XP?
Old Jan 23, 2010 | 02:23 AM
  #76
Yes XP , on two different computers,
Old Jan 23, 2010 | 02:35 AM
  #77
Odimus's Avatar
if the restore point doesn't work (choose one from November) you can go to your security setting and reset to defaults...tuen your firewall off and try to go to the Kawi Forum and then turn it back on...it may be a setting in the firewall...
Old Jan 23, 2010 | 03:44 AM
  #78
chik636rydr's Avatar
Dan, it is likely your antivirus software causing this issue. Temporairly disable your antivirus then try browsing the site. In fact, I am almost certain that is your issue.
If that doesn't work, I still think it would be active x settings. I am sure you computer has downloaded some Windows updates in the meantime automatically which probably patched a "fix" that didnt need to be fixed. lol
Old Jan 24, 2010 | 01:27 AM
  #79
RimBender's Avatar
s0.2mdn.net just stalled this page to load, more doubleclick garbage
Old Jan 24, 2010 | 03:15 PM
  #80
^ active x shiznit
ZX9 Guy
Jul 15, 2013 02:50 AM
450guy
Sep 3, 2010 02:45 AM
gwalleye
Jan 20, 2009 06:05 PM
BlackNinjaZX6R
Jul 18, 2007 05:06 AM
