Stiff Steering? Something Not right?
Old Apr 25, 2010 | 10:34 AM
Pepe72's Avatar
Default Stiff Steering? Something Not right?
Hi Guys,
Came off my bike a few weeks ago (dirt track, just cruising) As I got back on, I noticed my front wheel was slightly shifted from its alignment. When i got home, I loosened clamps on forks and re-aligned front wheel then tightened all clamps again, but the steering has a slight stiffness to it. Doesnt appear to be any cables restricting the turning, but it doesnt feel completely smooth and wants steer very slightly straight?? , head bearings were also fine.... any ideas ?
Cheers Pepe
KLX250'06
Old Apr 25, 2010 | 02:36 PM
what year is your bike and how many miles are on it. We need some information before we can help. Most likely it's either a cable that is binding or your steering bearing is too tight.
Old Apr 25, 2010 | 04:38 PM
HeavyFuel's Avatar
Did you reset the tension on the steering head bearings? You might want to pull the fork tubes out and check the steering feel with out the weight of the front wheel and forks. Maybe see if the bearing races got dimpled or the cages got tweaked.
ADoug22
KX125
Mar 22, 2013 01:04 AM
drewbabich
Jul 30, 2012 05:43 PM
Pepe72
Apr 25, 2010 10:32 AM
moosep85
ZZR 600
Jun 25, 2007 02:58 PM
tonytouch
Ninja ZX-7R
Jan 21, 2007 07:03 AM
