STATOR ISSUE - No Voltage or Resistance
Old Jul 7, 2017 | 02:48 PM
lj-rubi's Avatar
I'm no Wyotech grad, but I think you found the source of the problem LOL
Old Jul 7, 2017 | 03:05 PM
afdfirefighter's Avatar
Ya it certainly doesn't take the head cashier at walmart to identify that one lol
Old Jul 7, 2017 | 05:19 PM
durielk's Avatar
Yea, those wires look like one of your problems, hehe!
Anyway, you have 6 yellow wires and 6 possible ways to wire them. I would put numbers on all of them first thing. Maybe you could put quick connectors on them.
You will need to push them back in the reveal to keep them out of the way of the flywheel & magnets.
Old Jul 7, 2017 | 05:35 PM
durielk's Avatar
I have never messed with an alternater, but I would imagine one of those wires is a common. It will have equal ohms when read with the other two. The other two would have twice the ohms. But this is a total guess. Do you have a motor winding service somewhere near you, they could probably help you out.
First try I would wire that common one to the center wire from the regulator, the other ones may not matter.
Old Jul 7, 2017 | 07:03 PM
Good call on that! I didn't even think of them having to be wired in a certain order. I will check into this and see what I can find.
Old Jul 7, 2017 | 07:28 PM
Brewster's Avatar
No common in this configuration. There are three coils involved. You should have equal resistance (0.2 to 1.1 ohms) between any two wires. The rectifier/regulator establishes the ground and hot.
Ride on
Brewster
Old Jul 7, 2017 | 08:04 PM
Ride on
Brewster
With that being said, I can solder any of the 3 yellow wires entering the stator cover to the alternator 3 yellow wires and I will be fine?
Old Jul 8, 2017 | 12:29 AM
durielk's Avatar
Again, I am not an expert on alternators, but if they are all the same & none are common, I would think it doesn't matter. All the sorting out must be done with the diodes in the rectifier.
Old Jul 8, 2017 | 03:14 AM
GBAUTO's Avatar
I'd say that the harness got snagged and caused this damage. Since this a 3 phase alternator, just connect the damaged wires and all will be well...
zl PINHEAD lz
May 20, 2017 07:15 PM
dan888
Feb 5, 2013 05:29 AM
NorthRider
Feb 7, 2010 03:00 AM
sup_uni
Jun 8, 2007 02:03 AM
clay7160
Apr 6, 2007 12:00 AM
