STATOR ISSUE - No Voltage or Resistance
Old Jul 6, 2017 | 01:14 PM
afdfirefighter's Avatar
Default STATOR ISSUE - No Voltage or Resistance
Has anyone ever seen this happen? I just got this 2012 with 481 miles. Basically off the showroom floor. Took it on my first ride (after being on the battery tender) and it was dead when I stopped for gas after about 15 mins. The headlight must drain this battery super fast. Nonetheless, I am getting no voltage or resistance on the stator at all. I am going to pull the cover tonight but has anyone ever experienced this?
Old Jul 6, 2017 | 02:50 PM
Brewster's Avatar
Is your multimeter set for AC? When you say "no resistance" do you mean near zero or infinite?
Ride on
Brewster
Old Jul 6, 2017 | 02:52 PM
Ride on
Brewster
Yes sir. I had it set to AC. I mean no resistance at all. Like the wires have been disconnected from inside the cover. I am not sure what is going on with this thing.
Old Jul 6, 2017 | 10:19 PM
durielk's Avatar
Get a new battery, I seriously doubt anything is wrong.
I have no idea what wires your talking about or why they should have resistance.
What colors are they?
Old Jul 6, 2017 | 10:22 PM
i have already replaced the battery. I'm checking the three yellow wires as the manual states. There is NO VOLTAGE coming from them. Therefore it cannot recharge a battery.
Old Jul 6, 2017 | 10:23 PM
stator wires should have voltage and resistance. Read the manual under charging system.
Old Jul 6, 2017 | 11:24 PM
durielk's Avatar
Do you have the bike running when you check the wires?
Old Jul 7, 2017 | 12:42 AM
Lol yes when checking voltage
Old Jul 7, 2017 | 04:53 AM
GBAUTO's Avatar
If you are certain the readings your meter is indicating then it's time to pull the stator cover and inspect for obvious signs of failure/burning of the harness/coils. Based on the meter readings I suspect bad windings.
Old Jul 7, 2017 | 01:52 PM
Did that last night. Has anyone ever seen this?? How does this happen? What keeps these wires from being torn out again? Is it missing a clip or anything?
