Starter switch inconsistent
Old Mar 25, 2011 | 06:11 PM
tom edison's Avatar
Default Starter switch inconsistent
After changing the handle bars, the starter doesn't always connect while in gear. I have to pull the clutch lever a couple of times then it usually works. It works fine in neutral. Anyone have a similar problem?
Old Mar 25, 2011 | 06:29 PM
ol'klx-er's Avatar
Sounds as though something is haywire with the clutch switch. I've done the clutch and sidestand switch delete. Parts that aren't there can't cause problems.
Old Mar 25, 2011 | 10:19 PM
T_i_G_e_R's Avatar
happens to me too .. i just shift up to neutral no biggie
Old Mar 25, 2011 | 10:28 PM
mel brooks's Avatar
You can put a jumper wire in the clutch switch, rendering it 'ineffective'. One of the first things I did to my 'new to me' 2009 SF.
Old Mar 25, 2011 | 11:23 PM
I started having a problem with mine while trying to start it in gear. Mine got to where if I pulled the clutch in too far the switch wouldn't work. It had a sweet spot. I recently removed it altogether.
Dan
Old Mar 26, 2011 | 01:56 AM
turnsleft's Avatar
Mine is the same way Tom. Also it resets the trip meters and the clock. Whats up with that.
Old Mar 26, 2011 | 02:29 AM
ol'klx-er's Avatar
Check all your ground connections.
Old Mar 26, 2011 | 09:49 PM
turnsleft's Avatar
Default duh
Thanks; never thought of a ground problem. I cleaned the battery ground and it works fine. But then they most always work in the shop.
Old Mar 27, 2011 | 05:12 AM
Gobius's Avatar
+1 Usually I see this after I've pulled it out of a mudhole or recovered it from the shrubbery, so I'm just happy that it starts at all. So far, I've just bumped it back into neutral, waited for the water to drain from the airbox, and she's always fired. If all I have to do is pop it into neutral, then I'll take it!
sancho42
Oct 26, 2009 01:50 AM
oldschoolkawi
Jun 26, 2008 09:03 PM
dcorlando
Nov 9, 2006 11:47 PM
Finger Mullet
Sep 24, 2006 10:49 PM
gotrice
Jan 6, 2006 01:57 AM
