Stalls under hard braking at idle
Old May 13, 2013 | 03:00 AM
durielk's Avatar
You never said you adj your air screw, or did you just set it?
Old May 13, 2013 | 03:47 AM
phil_r's Avatar
I thought I had it, but I just went and screwed with it and I am pretty sure this is my issue. I turned it in to 1/4 turn and it idled like crap. Went for a quick burn and it no longer stalls when I jump on the brakes. If i turn it out to smoothen the idle I am back to stalling with hard brake. I can turn it out to about 5 full turns and there is no difference between 1/2 and 5.
At least I am making progress, however it is getting to late to be screwing around on the street with it tonight.
Thoughts?
Old May 13, 2013 | 03:53 AM
phil_r's Avatar
Currently I have a 115 Main, P6 Needle Jet, 15 pilot jet and 9DZH6-50 jet needle. 2100ft ASL with the stock airbox cover and snorkel on.
Old May 13, 2013 | 04:17 AM
RockabillSlapMatt's Avatar
You and I are having the same issue. I thought I was too rich so I turned it more lean, but it seems to be doing the same thing! AGH
Old May 13, 2013 | 04:24 AM
durielk's Avatar
I don't have your carb, I got a TM33 with a 32.5 pilot jet. But if you have it @ .5 turns out to get it to run right, that jet is too big.
Old May 13, 2013 | 04:31 AM
phil_r's Avatar
Just to confirm you are saying go from a P6 to a P4? Figures, that is the one part Niche Cycle didn't have when I ordered the carb.
Old May 13, 2013 | 04:54 AM
6thgear's Avatar
Have you checked to make sure your petcock is providing enough fuel to the bike? I had a issue before that was a mixture of a bad petcock and a vacum seal issue. Bike didn't get enough fuel when the engine was not revving.
Old May 13, 2013 | 12:10 PM
mustang's Avatar
I'm stumped....
I just installed a TM36 pumper in an 09 KLX250S with an FMF Slipon and stock cylinder. Bike runs amazing except under hard braking at idle when it just stalls. It then doesn't start on the first flick of the starter like usual, I have to crank it a couple times. Anyone have any idea what could be causing this? At first I thought it was tight throttle cables but that doesn't seem to be it now that they are re-routed. I can mimic the same stall condition parked in the driveway at idle by holding the front brake and compressing the forks very quickly. Same thing when I hold the front brake and lift quickly.
It also has an IMS tank.
Ideas?
Phil
I've had this exact problem before. In my case, a tiny piece of crud got behind the choke plunger. Even though I would push the choke in to turn it off, that piece of dirt kept the plunger from fully seating, and allowed fuel to flow directly from the fuel bowl into the venturi. So under hard braking, fuel would slosh in and flood the engine out. That would also explain why when you lean the bike to the left (choke side) it floods out, but leaning it to the right has no effect.
This may not be your problem, but it's something to check. Remove the choke plunger and make sure all is clean, and that nothing is interferring with the choke ****.
Old May 17, 2013 | 04:05 AM
phil_r's Avatar
Looks like I have a couple things to check out. Its going to be a month or so while I am on ex but I will definitely report back what the issue was.
preload
May 24, 2021 02:58 AM
ttakata73
Aug 27, 2010 03:29 PM
Ride r
May 30, 2010 01:52 PM
horizonod
Jan 10, 2009 04:42 AM
Bas2thesem
Mar 30, 2008 04:55 AM
