stall not start in water
Old Jun 5, 2007 | 02:35 AM
mudjunkie's Avatar
Default RE: stall not start in water
hey guys,
I opted to re-route the existing carb vent hoses on my bike..instaed of adding a T and a second set of hoses..I had it out for a short run tonite..not in water..just road ride and it seemed to run fine, BUT Iwas wondering if there was a difference between re-routing the hosescompared to adding the T and extra hose to each vent? or am I ok in re-routing alone? Thx again
Old Jun 5, 2007 | 04:47 PM
adaycj's Avatar
If by "re-routing" you mean you pointed them up or made a dip in them, it will cause a problem. The carb vent is designed to allow thecarb bowl to have a atmospheric reference. Since the outside air pressure can't get in under water, the engine runs poorly or stalls. The problem is, when the bike is dumped gas can come out of the tube, and moisture can get inanytime. Since the line is normally running downthe moisture or gas just leaks outwhen normal operation resumes. If you run the line up, or create a dip where water or gas can collect it can block the line with no way to get rid of the offending liquid. Then you get the poor running and stalling, just likewhen you are in a deep puddle. Really it is the same result, the line is plugged. Even worse, a year from now when it happens, the last thing you will think of is your carb vent as you tear into various things trying to figure out why it runs bad.
The "T"mod, when correctly done, as shown in the picture attached by another member allows the best ofboth worlds. Air can get in (and out) even if the vent line is submerged, butthere is a placefor gas or water in the line to flow down and out.
So, no. Rerouting the line will not work. It needs to point down.
Old Jun 5, 2007 | 08:56 PM
grafxguy's Avatar
AHHH Grasshopper.. you did not do the required reading of the entire KForum..
89 Ninja
Oct 19, 2007 07:35 AM
Cold Iron
Jul 24, 2006 09:47 PM
rickmedina
Jun 10, 2006 05:41 AM
dharnie
Oct 28, 2005 03:04 AM
