Spring behind oil filter
Old 11-02-2011, 04:29 AM
2007 Green Machine's Avatar
Originally Posted by EMS_0525
Just bend the bottom of the spring to fit tight and it wont fall out at all... did that a couple years ago, best thing ever.
That's what I'm going to do next time I change my oil! I never thought about it until I started this tread. In fact I think this may have been my very first thread I started. Really happy that I joined this forum!
Old 11-02-2011, 06:56 AM
turnsleft's Avatar
Bend the spring~~ good idea Dan. I lay the bike over and half fill the oil filter hole with oil before I put in the filter[KTM trick~posta be easer on the filter or so I was told], not had a problem. I'm gona bend the spring next time tho.
Old 11-03-2011, 04:20 AM
DYNOBOB's Avatar
This thread was timely...changed oil for the first time today. Bent spring slightly and it worked perfect.
Old 11-05-2011, 01:23 AM
Xerxes's Avatar
+1 on bending the spring.
Fact is, little tips like that are a lot of the reason I joined this forum in the first place when I got my '07.
Wisdom is what you can learn from others, experience is self taught. I'm old enough to be proud of the fact that I can learn things from others that will save me time and aggravation. Funny what a grey hair or two can do......
Old 11-07-2011, 09:53 AM
I could show you a ton of ways to change a tire wrong... lol....
Old 11-07-2011, 10:17 AM
WestOzKLX's Avatar
Last time I got a flat I didn't even take the wheel off, just popped the tube out, patched it and fitted the tyre back on. Saved a little time.
Old 11-07-2011, 10:28 AM
Wow, that sounds more difficult... ive never had luck patching tubes... I can change a tire in the garage in about 20 mins. Took awhile to learn the proper way to do it though.
  #28
Old 06-28-2020, 04:56 AM
klrguy's Avatar
Red face
so,,, ive changed my oil a couple times now on an '04 klr 250 and haven't seen any spring. ??> its not stuck on the back cause i have looked up in there. Does anyone know what happens if you've been riding without said spring ? and now that i think of it,,, i do remember finding a mystery spring on the garage floor sometime back. probably just after i changed the oil the first time..
  #29
Old 06-28-2020, 11:29 AM
2004 KLR parts schematic...
  #30
Old 06-29-2020, 08:08 AM
klrguy's Avatar
thx 678, ive been looking, im thinking that spring is inside that piston or valve bypass along with that pin, i can see the pin inside of it and it holds back a spring, what do you think ?
Quick Reply: Spring behind oil filter
