Spring behind oil filter
Old Apr 10, 2011 | 03:23 AM
2007 Green Machine's Avatar
Default Spring behind oil filter
Changed the oil on my bike today for the 3rd time and I'm sick and tired of the spring behind the oil filter. I almost have to lay the bike down, holding it up with my legs to get it back in so it stands straight up. Has anyone removed this spring. The only function I see is to help push the oil filter out.
By the way it's a 2007 klx 250. For what ever reason I cannot create a signature.
Old Apr 10, 2011 | 03:26 AM
Now my signature shows up!
Old Apr 10, 2011 | 03:30 AM
Bend the spring open a bit on one end (make the diameter larger)and then put that larger end in the bike first. It will stay right where you put it for the rest of eternity. No more laying the bike over etc.
Dan
Old Apr 10, 2011 | 03:32 AM
Thank you for the very fast reply. Never even thought of that. So I should keep it in there then right.
Old Apr 10, 2011 | 03:34 AM
Stroker331's Avatar
Put a dab of grease on the spring and it'll hold it in there. You need the spring.
Old Apr 10, 2011 | 03:59 AM
Hey I just saw that you're in Ft Atkinson My grandfather lived on the river just downstream from I-90 (Edgerton). You should check out some of the dual sport rides in the area. There is one next weekend in Leaf River IL, South west of Rockford. Another that takes place in the fall is real close to you. The Bucky is in Cross Plains WI, just west of Madison. Great places to ride off road, since we don't have much to choose from around here.
Dan
Old Apr 10, 2011 | 04:03 AM
Grease works, but I'd bend it and be done.
Old Apr 10, 2011 | 09:49 AM
neilapples's Avatar
bending is the best and easiest way to go.
Old Apr 10, 2011 | 12:23 PM
LearjetMinako's Avatar
Dan
+1. Done this myself too, and I never had to mess with the spring ever again.
Old Apr 10, 2011 | 12:39 PM
ndery's Avatar
There is always the "dental floss trick" witch is holding the spring on the filter using a 12 inch stringof dental floss and then remove it as soon as the spring is seated in the engine...
