speed?
Old Jul 17, 2010 | 05:04 PM
bweekley's Avatar
man the S model must be faster then the SF I've had my on I-80 with throttle pegged and my speedo reads 80 on flat ground which is like 73mph, sure there a few down hill sections that get me up to 88 per speedo but that is it.....him must be the 45 tooth rear might be time for a new mod.
mine is a 2009 sf with stock 14/39 gears a fmf q4 a dyno jet kit and uni filter with snorkel removed and a 218 pound rider.
will the 45 rear give me more torque?
Old Jul 18, 2010 | 07:41 AM
KDXmike's Avatar
You guys are crazy. 83mph is about all I've done.
M
Old Jul 18, 2010 | 08:14 AM
Blueraven's Avatar
about 210 on my old hayabusa.
about 85 on my 06 klx before i got the death weave and decided 70 is just fine...
Old Jul 18, 2010 | 07:33 PM
ttakata73's Avatar
I was only able to get my DTracker (KLX250SF) up to 88mph WOT on a flat highway, but I weigh 200 lbs and had another 50 pounds of travel gear on board. I found the bike amazingly stable and wanted to go faster.
Old Jul 19, 2010 | 01:56 AM
09'Kawi250s's Avatar
Originally Posted by Karitane Pete
The 96 MPH was on gravel
WTF? theres no way in %#$* can do more than 70 or so on gravel. i get a high speed wobble at like 60 on dirt/gravel and at about 90 on-road. i dont believe it unless i saw it
Old Jul 19, 2010 | 02:21 AM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
I think if the suspension is set right it's feasible
Old Jul 19, 2010 | 07:57 AM
maninthesea's Avatar
So speaking of suspension settings vs wobble. I have noticed that after I stiffened front and rear springs and around the same time switched from a 110/(not sure if it was 80 or 90 now) rear to a 140/80 rear I now get some shake when accelerating hard into and thru the 60's and70's Have not tried to hard accelerate any faster than that. But if I bring the speed up a little less quickly I dont get the wobble.
I was thinking it was from bigger taller rear and was thinking next rear will be a 130/80. Is it more likely from the stiffer springs?
Rear spring went in at same time as new tire. Front springs preceded by about a week and I did not notice any wobble.
Cheers Jim
Old Feb 10, 2011 | 12:43 AM
dean2121's Avatar
i got about 96 slight down hill all stock reved pretty high she was screaming ha
Old Feb 10, 2011 | 10:35 AM
David R's Avatar
83 or 84 is all I Can get on out of my 09SF Even with the 351. I have not changed the gearing.I checked the speedo with a GPS. Bike reads 70 GPS reads 65 mph.
Its turning 10,000 rpm at 83 in 5th gear. RPM drops in 6th, but no MPH gain. Its outa power.
David
Old Feb 13, 2011 | 01:45 AM
Lutz's Avatar
I believe the highest I saw stone stock was 92 mph on a long fairly steep downhill. Maybe 88 mph or so on level ground. I haven't run it to top speed since I changed to a KLX300 pipe and rejetted.
Of course the above speeds are per the speedo on the bike, GPS was more like mid-80's top speed.
