sock vs. klx
Old Jul 30, 2013 | 11:31 PM
250SM's Avatar
Suzuki had sock gaurds way back on the dr250s lol
Old Jul 31, 2013 | 06:29 PM
durielk's Avatar
If I was to guess, I'll wager the shifting forks broke off inside the case. Seems more likely than shearing the gears, if the gears sheared, you could rotate them to the good teeth, then hit the broken off ones, it would sound terrible.
Old Jul 31, 2013 | 06:57 PM
Originally Posted by Highbeam
The shifting just means that you are getting the shift drum to spin. Time to take the right side cover off and see if power is making it to the input shaft.
If you put the bike in gear. With engine off. Can you spin the sprocket freely?
It is much easier to fix something under the right sidecover than to split the cases for internal tranny stuff. Most of the things that can pop are under the right cover.
Yeah, I'm still waiting to hear the response to your last suggestion about putting the bike in gear and spinning the sprocket by hand...engine off of course.
Old Jul 31, 2013 | 08:47 PM
I'll tell you what, 666...that's a first for me, and I'm old enough to have seen a lot of weirdness...LOL!
Old Jul 31, 2013 | 09:36 PM
Lutz's Avatar
Be sure to check out the rear hub too...pretty good potential that it is cracked and/or has bearing damage.
Old Jul 31, 2013 | 10:32 PM
Karitane Pete's Avatar
and check the rear axle is not bent.
666 you were lucky the rear wheel did not lock up and deck you on the freeway
Old Aug 1, 2013 | 04:26 AM
Brieninsac's Avatar
Meanwhile, someone is missing a sock. Let's not forget about them.
Old Aug 1, 2013 | 10:04 PM
any list of damage yet?
Towing to you :- $50 cash,
Towing for insurance company :- receive order number and have to wait 60 days for payment and then towing man has to pay tax etc
Old Aug 6, 2013 | 09:18 PM
durielk's Avatar
So, what's happened?
Old Aug 6, 2013 | 10:31 PM
Originally Posted by djchan
Well, that socks....
Hahahaha!!! I was just going to say that.
