smaller turn signals
Old Mar 10, 2013 | 10:06 PM
10thmountainman's Avatar
Default smaller turn signals
So I have a 06 klx and the turn signals hang out almost as far as my grips, I am constantly hitting them when throwing my leg over. I would like smaller ones but not sure if I should go with LEDs or regular bulbs. Also how hard is it to replace? anything to think about before purchasing? where is the best place to buy?
Old Mar 10, 2013 | 11:12 PM
HunnieToast's Avatar
I went LED for my replacements, I liked them better than anything else because I was having the same issue as you. I have a 2012, so not sure how much the difference is with the mounting of it all, but I thought is was really easy to be completely honest with you.
Here is the link that I went with for the rear:
Motorcycle Universal Flush Mount 14 LED Turn Signals Light Indicators Amber 12V | eBay
Old Mar 10, 2013 | 11:17 PM
those look cool, how well can they been seen in sunlight? I heard LEDs were harder to see in the sunlight
Old Mar 10, 2013 | 11:23 PM
You are correct, they are not easily seen in sunlight I won't lie. But I am happy about them and that's what I wanted mostly.
Old Mar 11, 2013 | 12:41 AM
Subasaki's Avatar
competitionwerkes.com...universal turn signals...$20..worked well
Old Mar 11, 2013 | 03:08 AM
Brieninsac's Avatar
Old Mar 16, 2013 | 02:46 AM
I got fed up after trying a few cheap sets and went with these:
Here they are on someone's dual sport, I have them on a KLX650 and a 550 Zephyr:
They're the rear turnsignals from a Buell Ulysses. They're $15.99 each, but they are DOT legal, have a really flexible stem, and bright enough - but best of all - they don't stick out like Mickey Mouse ears. Worst thing, I had to go to an electronic no load (or variable load) relay from Autozone ($9) and soldered on wire exensions cut from my OEM signals.
But it was absolutely worth it. They look good, weren't that costly, should be available for several more years (made in Italy too) from HD dealers that are willing. The parts guy at AD Farrow's in Columbus Ohio told me he's had a lot of dual sport guys buy them. I liked them so well on the Zephyr that I did them on the KLX - again worth every penny of the roughly $75 total. The reason for the relay change is they use a 3w bulb, making higher draw.
joelcool64
Sep 28, 2011 02:09 PM
DOUBLE
Jun 15, 2010 02:15 AM
MK1gti20v
Jan 10, 2007 07:29 PM
a zx6r4u
Nov 5, 2006 06:33 AM
deej
Nov 2, 2006 04:11 PM
