Silicone Hose kit
Ever heard of google?
http://www.rscycles.com/images/samco..._Hose_Kits.htm
KLX 250 1998 - 2003 Coolant KAW-10 $117.00 CK KAW-10 $42.22
http://www.samcosport.co.uk/usa/down...SA%20BIKES.pdf
KLX 250 1998 - 2003 Coolant KAW-10 117.00 CK KAW-10 42.22
http://www.sfsperformance.co.uk/prod...?make=kawasaki
KLX250 / D Tracker 98-07 (4) - NEW! Coolant MBC150
http://www.sporthoses.com/kits/bike/kawasaki/1975
http://www.langstonmotorsportsriders...ator-Hose.html
http://japan.webike.net/
I just ordered a red set by DRC from the above website. None of the rest of the sites had the right model number listed. Good luck.
I was thinking I would get some silicone hose and replace the stock. Now I am assuming that I need to get a kit with prebent hoses becuase I wont be able to put nice bends in the right place. Anyone know if its possible to make the bends youself and if so how do you do it?
Cheers Jim
Cheers Jim
dude, samco hoses, *drooollllllll*. if i was still all jdm nut like i use to i would be all over those, but then again i would probally have a supermoto then. i like drc, they never let me down yet, and there 60 buck cheaper. ill save the 500 dollar clutch/flywheel set ups, carbon fiber bits and the like for the car.
The bends are molded, can't really do it yourself. If you had to bend a straight hose sharp you could put a spring inside of it to keep it from collapsing?
Cheers Jim
Cheers Jim
Molded maks sense. I was thinking about it the other night and silicone is now used for high end baking molds and it keeps its shape so head is not the answer. Oh well was worth exploring.
Cheers Jim
Cheers Jim
