Signal Minder Running lights...
Old May 27, 2010 | 11:42 AM
tremor38's Avatar
Originally Posted by jacksonriding7
Okay so now I have conflicting reports.... Guy at dealership (who owned same bike) said that LED's are a direct fit swap, just tie into existing wires and go. Tremor's comment (and some bikes are like this, reflects the kind of system where the lights ground across each other and if you dont isolate the indicator light by creating an independent ground and using diodes for input from either side then you get 4 way LED flashers. I'd really LOVE for even just one guy on the forum to say he put in LED's and didn't have to do the mod.. or found he did. Any takers?
I am again speaking from an 06/07 frame of reference..not sure which bike you own. If you replace all of your incadescent turn signal bulbs on the 07/08 with LED's the load will be less, causing the bi-metalic flasher to flash way too fast (deforms less with less current causing it to close faster). There are documented cases of that coming from 06/07 owners in this forum, but that result was predictable anyway. If your led indicators come with load resistors, that's a different story, but I'm sure you're aware of that.
There are also documented posts of the current cross-feed through the indicator light (06/07, this forum).
I'm not sure if the 09 has a solid state flasher, but if it does, and you own an 09, you're probably good to go.
Old May 27, 2010 | 04:39 PM
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
Hadn't thought of the LED's coming with load compensators. That's a possibility, maybe dealership guy bought lights that had it and didn't think of it. Personally, I'd rather do all the work to make it right, installing LED and not taking advantage of the power savings doesn't make much sense to me. Now I gotta figure out what kind of Diode's to use.
DOUBLE
Jun 15, 2010 02:15 AM
khck512
Jan 8, 2007 12:31 AM
markturbo
Nov 25, 2006 07:27 PM
taystyl
Apr 20, 2006 06:35 PM
MoserFtWayne
Mar 15, 2006 10:14 PM
