side stand slop
Old Mar 14, 2016 | 09:11 PM
MJG's Avatar
MJG
Default side stand slop
I bought this used a year or so ago
the side stand moves out, and bike leans over more- when you rest bike on it
I think I recall looking at a new one one day and its about the same
are these things sloppy
anyone do any fix or upgrade to take out the slop
Old Mar 14, 2016 | 10:36 PM
MaximusPrime's Avatar
Mine was extra sloppy after it finally broke and was rewelded, so I added a washer that I ground thinner and slid inside the kick stand.
The result was as desired, enough play to let the stand settle a bit when the weight of the bike rests on it.
Old Mar 15, 2016 | 08:16 PM
GBAUTO's Avatar
I had the same issue on my '12. I resolved it just like Ben did-make a shim to take up excess clearance on the pivot. It's a bit of a pain to get it right but it will fix the problem.
Old Mar 16, 2016 | 01:17 AM
dpippin's Avatar
gbauto
Please check your PM's for a message I sent you.
Old Mar 16, 2016 | 08:12 PM
Oldad's Avatar
Default Ditto
Shim is the way to go. I tried squeezing the stand together and tightening the bolt , but found that the bolt is a shoulder bolts so will not tighten past a certain length, so just spread the stand back to original width.
karlcchen
Sep 26, 2011 09:14 PM
neilaction
Jul 17, 2008 02:05 PM
WestOzKLX
Mar 25, 2008 01:34 PM
mtcaves
May 9, 2007 08:01 AM
neoplanet
Mar 11, 2007 04:27 AM
