Shut of while riding. Will not crank until I push the bike around a bit
Old Oct 6, 2018 | 03:25 PM
IKLXG250's Avatar
Originally Posted by IKLXG250
Never been swimming that I know of. I just purchased the bike second hand 3 months ago with 9,000 miles for $1,100 so I don’t mind fixing a couple of things here and there
Is there any signs too look for that would hint that it has gone for a swim?
Old Oct 6, 2018 | 03:35 PM
Brewster's Avatar
where would I be able to find the gas vent??
Usually it's the tube coming out of the gas cap.
Ride on
Brewster
dp19's Avatar
Check your kickstand switch. If the starter won't turn your problem is electrical.
Old Oct 6, 2018 | 11:25 PM
durielk's Avatar
There are several interlocks on the starter..., clutch (if in gear), kickstand, kill switch.
Sounds like you may have mulitiple problems, as if those switches are active, it will not start nor run.
Once running, they will not make it run bad, only shut it down. I don't know about why it wouldn't start, but the other sounds like a carb issue.
When you hit the starter, do you hear a clunk when it don't turn over?
Old Oct 7, 2018 | 12:18 AM
IKLXG250's Avatar
I did notice a slight rattling sound once the bike turned on from the left side of the bike near the starter
Old Oct 7, 2018 | 12:38 AM
durielk's Avatar
So, your front light is on and you hit the starter and .... nothing. Maybe some raddle? Does the lights dim? (try it at night or in a garage)
Is it intermittant problem? Like after it runs for 20 min, or issue from some point in time and aways since?
Old Oct 7, 2018 | 12:58 AM
IKLXG250's Avatar
yea front light and dash is on but won’t crank until i push it around. I have not checked if the light dims when I try to start. No the rattling starts as soon as the bike starts and then the bike will turn off on it’s own after about 2 minutes
Old Oct 7, 2018 | 02:41 AM
durielk's Avatar
Doesn't sound good. I was thinking carb issue, but that rattling may be cam chain. If it was really loose it may jump a cog, i don't know. Why would it not turn over though.
I had a starter issue, but I was getting a big clunk when you hit the button, then it locked up. Doesn't sound like the same thing. If it is rattling after you start it, constantly, I would pull the valve cover and see if the cams are in time, especially if the cam chain is loose when you get in there.
jacksonriding7
Jul 31, 2015 02:17 AM
bc55
Aug 26, 2013 10:07 PM
brent
KX250 & KX250F
Feb 18, 2012 01:50 PM
bmx_lar
Oct 12, 2010 12:55 AM
sinkoman
Aug 28, 2007 04:03 PM
