Should I go back to stock pilot jet? need help
Old Feb 13, 2018 | 06:43 PM
  #41
horror_fan's Avatar
Originally Posted by IDRIDR
I believe Brewster is saying the float needle may have a slow leak. Set up your tube test for a few hours.
I've never heard of doing the float check with the bike running.
I just bought a new float needle ..no harm in having a spare or maybe it will fix the issue.
Old Feb 13, 2018 | 06:48 PM
  #42
horror_fan's Avatar
Originally Posted by klx678
Service manual page 3-13 shows how to set it with dimensions and how to check it.
got it found it.
wow so many times I've looked through this pdf manual using the search terms "carb" as well as manually scrolling ...and was never successful
Old Feb 13, 2018 | 06:53 PM
  #43
horror_fan's Avatar
how bad is it that the carb didn't have a o-ring? it doesn't leak but I noticed there wasn't an o-ring the first time I took the carb apart.
Old Feb 13, 2018 | 07:08 PM
  #44
Originally Posted by horror_fan
got it found it.
Cool. That happens.
Old Feb 13, 2018 | 07:30 PM
  #45
You say you smell fuel when parked. A missing o-ring could be the culprit.
Which one is missing?
Old Feb 14, 2018 | 12:32 AM
  #46
horror_fan's Avatar
float bowl gasket I believe its called. just that square shaped o ring that goes around the edge where the float bowl touches the carb.
could be the reason..
but I believe most of the gas is because
1) I may do a wheelie, drive through a park with rumble road, or do a power slide (and dip the bike low) ...causing gas to get into the tank overflow tubes (which sometimes forget to unplug since I plug them up after letting bike air out to limit smell in my garage)
2) prob something wrong with the float needle getting tiny small drips from the float bowl ..
3) maybe excess fuel in the carb (throttle port?) or whatever its called ..because Im a newb idk...
Old Feb 14, 2018 | 12:05 PM
  #47
I vote float bowl gasket missing. Seeps out there. Gas can easily seep between those two metal surfaces without any gasket to stop it.
Old Feb 14, 2018 | 12:55 PM
  #48
durielk's Avatar
That carb had a gasket, u just lost it.
Old Feb 14, 2018 | 04:48 PM
  #49
horror_fan's Avatar
I've already ordered one from the Kawasaki dealer.
only thing is I dont see any gas comin out...
  #50
horror_fan's Avatar
not seeing your point ... but the bike was like that when I bought it.
I ordered a new one from Kawasaki. should be here by Monday.
pwjm
Aug 11, 2015 10:28 PM
WHIP-N-DIP
Aug 14, 2012 11:45 PM
Lobster Grrl
Jul 1, 2011 11:03 PM
acgill
Jul 2, 2007 03:54 AM
