Shorter clutch lever?
Old Aug 14, 2007 | 07:39 PM
kgwld1's Avatar
Default Shorter clutch lever?
Does anyone know of a shorter clutch lever that will bolt on for one finger clutch slipping? I don't want to cut the stock one down.
Kevin
Old Aug 14, 2007 | 07:48 PM
ZX1100F1's Avatar
Default RE: Shorter clutch lever?
I use an ASV C5, it works well, was relatively painless to install and I can use one or two fingers which allows better control of the bike since my other fingers remain on the grip.
Old Aug 14, 2007 | 09:18 PM
HawaiiRider's Avatar
Which ASV c5 do you have? They don't have our bike listed on the fit page. Is it just the universal and any chance you know whick brake one will work? Thanks for the input.
Old Aug 14, 2007 | 09:45 PM
bryantjt's Avatar
I use the MSR Pro raptor shorty, super beefy lever and mount. Got it from www.rockymountainatv.com
Old Aug 14, 2007 | 10:32 PM
digitaloverkill's Avatar
http://www.denniskirk.com
Part Number (571091) $9.99[*]Aluminum construction with the DeHandler feel
*Replaces the stock handle.
Old Aug 14, 2007 | 10:47 PM
ZX1100F1's Avatar
ORIGINAL: HawaiiRider
The universal levers are the ones I use.
Old Aug 14, 2007 | 11:12 PM
FM_Thumper's Avatar
I got my shorty clutch lever when itsnapped in halfwhen I dumpedthe bikeon a technical trail. It broke cleanly and it looks like it was cleanly cut off.Talk about lucky. [sm=lol.gif]
Old Aug 15, 2007 | 01:32 PM
Truckman's Avatar
Ditto....I did the same thing from the same place...love the lever.
When you swap the lever make sure you solder the 2 wires together for the clutch switch and then heat shrink them and tie them up out of the way....downside? you can look like a real idiot when you leave the bike in gear and hop on a nail the starter button and the bike launches because you never pulled in the clutch.....you remember after you do that once or twice.
Old Aug 16, 2007 | 12:57 AM
klxrdr's Avatar
+1 for msr pro raptor
i use the full length one though
Old Aug 16, 2007 | 12:08 PM
vfrpilot's Avatar
ORIGINAL: ZX1100F1
+1
