is the shift shaft problem the "high mileage shift star"
It's a JIS screw head, not Philips. VERY easy to confuse. JIS screwdriver would have helped. Philips screwdrivers are designed to spin out of the screw head. A quality JIS screwdriver will stay in the screw head.
Hmm, widening the gap...
Why didn't I think of that?
I'll have to take a better look at the shaft when pulling off the shifter to widen the slot. I suspect that it'll be worn enough to warrant replacement.
It'll last longer next time around since I don't fall nearly as much as I used to.
Doh, just jinxed myself.
"JIS-spec cross-head screws are generally marked with a single raised dot or an "X". JIS always fit Phillip fasteners, but because of slight design differences, Phillips drivers may not fit JIS fasteners. (unless the tip is ground down a bit). "
cpr1
May 30, 2011 04:44 PM
davehayward1
Sep 20, 2010 07:28 AM
