Shift Lever
Old Feb 27, 2019 | 02:41 PM
Ti3m's Avatar
Default Shift Lever
The shift lever on my 2009 klx250sf is bent. Can someone recommend an aftermarket replacement? I wouldn't mind replacing the rear brake lever to match...
Old Feb 27, 2019 | 03:57 PM
Abramsgunner's Avatar
There's a bunch of threads on this... If I remember correctly, the shift lever for a 93-09 XR650L fits and is longer. I tried the MSR steel lever for the XR650L and it was too stiff (might cause damage in a crash) so I went with an used OEM example for the same bike and it has been perfect. It bends in a crash but is easy to bend back into shape.
NOTE: Double check my numbers, as it has been close to two years since i bought mine.
Old Feb 28, 2019 | 12:19 AM
azdeuce's Avatar
Default Zeta
zeta has some cool ones.. check those guys out..
Old Mar 2, 2019 | 03:08 AM
turnsleft's Avatar
Yamaha Banshee shifter on a 09 KLX . Be care full what shifter you put on your KLX if it is to tuff it can hurt your tranny if you toss it in the dirt.
Just bend it to fit
Old Mar 2, 2019 | 11:21 AM
Tacoma660's Avatar
are the zeta ones just as long as the xr650 lever?
Old Mar 2, 2019 | 02:14 PM
klxnoobie's Avatar
Maybe - ZETA RACING - I also like their adjustable brake pedal - ZETA RACING - I have their adjustable clutch and brake levers on my klx it's good stuff.
Old Mar 5, 2019 | 04:16 AM
drm's Avatar
drm
Bend it back, reuse it, and add a lever snake to keep it in check next time you dump it...your shift pin in the tranny will thank you for it.
addictedtogum
May 22, 2018 12:51 PM
Gummikuh
Aug 15, 2013 09:23 PM
bsj425
Sep 28, 2010 02:07 AM
blackhawk32
Dec 6, 2009 04:34 AM
tylercq
Jan 20, 2009 04:23 AM
