Safety-Visibility-LIGHTS Show them off
Old Mar 27, 2012 | 12:22 PM
stephenmarklay's Avatar
Default Safety-Visibility-LIGHTS Show them off
Unfortunately this is model specific,<2009 and >2009.
My real interest is for my 2006.
I have been thinking safety safety and more safety.
I think about the bikes I see on the road and what makes me aware of them
People are focused on the HI-Viz gear but I really don't think that is the answer. While it certainly can't hurt I don't think its the ultimate answer.
I have seen a few big bikes with big **** lights. A few with lights that strobe (daytime) as well. I notice these bikes.
To be seen in a way that a motorist takes notice and processes the info in a meaningful way has, in my mind, a lot to do with the perception of distance. We are small unlike a big car or BIGGER semi.
So how do we get BIG? BIG lights. Have you ever noticed how a really dim lighted vehicle seems slower approaching? Even bright bike lights are too low power to make someone not turn in front of you.
I want the brightest light in the front and the rear and even turn signals. Sure drivers of oncoming cars will not like a bright light but they will process that an hopefully be more aware of me.
On the front is the Trail Tech X2 the best option. Will HID work for a 2006? They only mention fit for klx 450 head light. I would love a light that strobes for daytime. Any one doing this?
Happy trails has a rear LED for the KLR650 that seems to work on the first gen.
What about the best and brightest turn signals? Again different for model years.
I am not doing this to see but rather to be seen. The to see part is a bonus.
THANKS!
Old Mar 27, 2012 | 01:35 PM
jeffzx9's Avatar
FWIW, here is a summary of the Hurt Findings (courtesy of Cycle Chaos website.)
Kinda lengthy, but an interesting read. What I seem to take away from this report, is that the single greatest factor for accident/injury prevention is the monkey holding the bars. Never ride intoxicated, always wear a helmet/gear, get properly trained and insured, ride DEFENSIVELY; never assume, ride within speed (and ability) limits, etc. Your odds of having an uneventful ride improve significantly if you just use your brain! Steve, I'm not being critical of your headlight quest. If it helps, I'm all for it. (really!)
These findings are summarized as follows:
1. Approximately three-fourths of these motorcycle accidents involved collision with another vehicle, which was most usually a passenger automobile.
2. Approximately one-fourth of these motorcycle accidents were single vehicle accidents involving the motorcycle colliding with the roadway or some fixed object in the environment.
3. Vehicle failure accounted for less than 3% of these motorcycle accidents, and most of those were single vehicle accidents where control was lost due to a puncture flat.
4. In the single vehicle accidents, motorcycle rider error was present as the accident precipitating factor in about two-thirds of the cases, with the typical error being a slide out and fall due to over braking or running wide on a curve due to excess speed or under-cornering.
5. Roadway defects (pavement ridges, potholes, etc.) were the accident cause in 2% of the accidents; animal involvement was 1% of the accidents.
6. In the multiple vehicle accidents, the driver of the other vehicle violated the motorcycle right-of-way and caused the accident in two-thirds of those accidents.
7. The failure of motorists to detect and recognize motorcycles in traffic is the predominating cause of motorcycle accidents. The driver of the other vehicle involved in collision with the motorcycle did not see the motorcycle before the collision, or did not see the motorcycle until too late to avoid the collision.
8. Deliberate hostile action by a motorist against a motorcycle rider is a rare accident cause. The most frequent accident configuration is the motorcycle proceeding straight then the automobile makes a left turn in front of the oncoming motorcycle.
9. Intersections are the most likely place for the motorcycle accident, with the other vehicle violating the motorcycle right-of-way, and often violating traffic controls.
10. Weather is not a factor in 98% of motorcycle accidents.
11. Most motorcycle accidents involve a short trip associated with shopping, errands, friends, entertainment or recreation, and the accident is likely to happen in a very short time close to the trip origin.
12. The view of the motorcycle or the other vehicle involved in the accident is limited by glare or obstructed by other vehicles in almost half of the multiple vehicle accidents.
13. Con****uity of the motorcycle is a critical factor in the multiple vehicle accidents, and accident involvement is significantly reduced by the use of motorcycle headlamps (on in daylight) and the wearing of high visibility yellow, orange or bright red jackets. (Note: the statistics which have just been released here in Australia - August 1996, DO NOT SHOW that "Lights on" legislation has worked!)
14. Fuel system leaks and spills were present in 62% of the motorcycle accidents in the post-crash phase. This represents an undue hazard for fire.
15. The median pre-crash speed was 29.8 mph, and the median crash speed was 21.5 mph, and the one-in-a-thousand crash speed is approximately 86 mph.
16. The typical motorcycle pre-crash lines-of-sight to the traffic hazard portray no contribution of the limits of peripheral vision; more than three- fourths of all accident hazards are within 45 degrees of either side of straight ahead.
17. Con****uity of the motorcycle is most critical for the frontal surfaces of the motorcycle and rider.
18. defects related to accident causation are rare and likely to be due to deficient or defective maintenance.
19. Motorcycle riders between the ages of 16 and 24 are significantly over-represented in accidents; motorcycle riders between the ages of 30 and 50 are significantly under represented. Although the majority of the accident-involved motorcycle riders are male (96%), the female motorcycle riders are significantly over represented in the accident data.
20. Craftsmen, laborers, and students comprise most of the accident-involved motorcycle riders. Professionals, sales workers, and craftsmen are under represented and laborers, students and unemployed are over- represented in the accidents.
21. Motorcycle riders with previous recent traffic citations and accidents are over represented in the accident data.
22. T he motorcycle riders involved in accidents are essentially without training; 92% were self-taught or learned from family or friends. Motorcycle rider training experience reduces accident involvement and is related to reduced injuries in the event of accidents.
23. More than half of the accident-involved motorcycle riders had less than 5 months experience on the accident motorcycle, although the total street riding experience was almost 3 years. Motorcycle riders with dirt bike experience are significantly under represented in the accident data.
24. Lack of attention to the driving task is a common factor for the motorcyclist in an accident.
25. Almost half of the fatal accidents show alcohol involvement.
26. Motorcycle riders in these accidents showed significant collision avoidance problems. Most riders would over brake and skid the rear wheel, and under brake the front wheel greatly reducing collision avoidance deceleration. The ability to counter steer and swerve was essentially absent.
27. The typical motorcycle accident allows the motorcyclist just less than 2 seconds to complete all collision avoidance action.
28. Passenger-carrying motorcycles are not over represented in the accident area.
29. The driver of the other vehicles involved in collision with the motorcycle are not distinguished from other accident populations except that the ages of 20 to 29, and beyond 65 are over represented. Also, these drivers are generally unfamiliar with motorcycles.
30. The large displacement motorcycles are under represented in accidents but they are associated with higher injury severity when involved in accidents.
31. Any effect of motorcycle color on accident involvement is not determinable from these data, but is expected to be insignificant because the frontal surfaces are most often presented to the other vehicle involved in the collision.
32. Motorcycles equipped with fairings and windshields are under represented in accidents, most likely because of the contribution to con****uity and the association with more experienced and trained riders.
33. Motorcycle riders in these accidents were significantly without motorcycle license, without any license, or with license revoked.
34. Motorcycle modifications such as those associated with the semi-chopper or cafe racer are definitely over represented in accidents.
35. The likelihood of injury is extremely high in these motorcycle accidents-98% of the multiple vehicle collisions and 96% of the single vehicle accidents resulted in some kind of injury to the motorcycle rider; 45% resulted in more than a minor injury.
36. Half of the injuries to the somatic regions were to the ankle-foot, lower leg, knee, and thigh-upper leg.
37. Crash bars are not an effective injury countermeasure; the reduction of injury to the ankle-foot is balanced by increase of injury to the thigh-upper leg, knee, and lower leg. 38.The use of heavy boots, jacket, gloves, etc., is effective in preventing or reducing abrasions and lacerations, which are frequent but rarely severe injuries.
39. Groin injuries were sustained by the motorcyclist in at least 13% of the accidents, which typified by multiple vehicle collision in frontal impact at higher than average speed.
40. Injury severity increases with speed, alcohol involvement and motorcycle size.
41. Seventy-three percent of the accident-involved motorcycle riders used no eye protection, and it is likely that the wind on the unprotected eyes contributed in impairment of vision which delayed hazard detection.
42. Approximately 50% of the motorcycle riders in traffic were using safety helmets but only 40% of the accident-involved motorcycle riders were wearing helmets at the time of the accident.
43. Voluntary safety helmet use by those accident-involved motorcycle riders was lowest for untrained, uneducated, young motorcycle riders on hot days and short trips.
44. The most deadly injuries to the accident victims were injuries to the chest and head.
45. The use of the safety helmet is the single critical factor in the prevention of reduction of head injury; the safety helmet which complies with FMVSS 218 is a significantly effective injury countermeasure.
46. Safety helmet use caused no attenuation of critical traffic sounds, no limitation of pre crash visual field, and no fatigue or loss of attention; no element of accident causation was related to helmet use.
47. FMVSS 218 provides a high level of protection in traffic accidents, and needs modification only to increase coverage at the back of the head and demonstrate impact protection of the front of full facial coverage helmets, and insure all adult sizes for traffic use are covered by the standard.
48. Helmeted riders and passengers showed significantly lower head and neck injury for all types of injury, at all levels of injury severity.
49. The increased coverage of the full facial coverage helmet increases protection, and significantly reduces face injuries.
50. There is not liability for neck injury by wearing a safety helmet; helmeted riders had less neck injuries than unhelmeted riders. Only four minor injuries were attributable to helmet use, and in each case the helmet prevented possible critical or fatal head injury.
51. Sixty percent of the motorcyclists were not wearing safety helmets at the time of the accident. Of this group, 26% said they did not wear helmets because they were uncomfortable and inconvenient, and 53% simply had no expectation of accident involvement.
52. Valid motorcycle exposure data can be obtained only from collection at the traffic site. Motor vehicle or driver license data presents information which is completely unrelated to actual use.
53. Less than 10% of the motorcycle riders involved in these accidents had insurance of any kind to provide medical care or replace property
Old Mar 27, 2012 | 01:47 PM
This is great. Thanks so much. I read it all with great interest. No doubt, none that I am the one who has to watch out for where I end up.
The headlight is the part I can't control as well. If a guy txting his wife or a kid who just left the bar sees a giant light approaching it helps my odds. I think.
Again, no apology required. If I stay upright its all good
Just a note: Combine #1, #6 and #7 and getting a big light is a no brainer. This could impact, according to this, 3/4*2/3=6/12 or HALF of all accidents.
Old Mar 27, 2012 | 02:12 PM
jeffzx9's Avatar
Yep; I agree^. My personal bias about retina-scorching lights on bikes, is this: I'm a rider. I can identify other riders (#7 above.) Although I understand why people use them, retina-burners still pi$$ me off. The 10% of drivers who qualify under #7, don't need to be driving (but do.) Using retina-burners is false security. "Oh, they'll see my 500-watt headlamps...I'll be safe." When we relax our vigilance, we get slammed. (Kinda how I feel about ABS brakes and seat belts, but that's another post...) Retina burners are fine. Just NEVER let your guard down.
Old Mar 27, 2012 | 02:29 PM
DYNOBOB's Avatar
Check out my LED driving lights and brake light.
Old Mar 27, 2012 | 03:32 PM
Lotrat's Avatar
It would be awesome if this was in a calculator.
42, engineer, no recent tickets or accidents, over 5 months with this bike, 20 years with a MC licence, insured, unmodified bike, helmet, some dirt bike experience. Low odds, but I still won't bet my life on them. Some people in cars just don't see motorcycles. Their brains don't register them. I've had people look right at me and still turn in front of me or change lanes into me. That's just the way it is. Watch for them and avoid them.
Old Mar 27, 2012 | 03:44 PM
Yes great points. I have done a lot of bicycling and even have been hit by a car (ended up fine). My experience from that carries over. Intersections are bad news. All intersections defined by any time a car can cross your path are bad actually. A bicycle also has certain disadvantages as well. In traffic having to drive on the right of flow can be dangerous. If you drive your bike on the left of the roadway people will run you over for fun. However, at times it is much much safer in that spot.
Old Mar 27, 2012 | 03:52 PM
I am pretty much in the same boat.
Your thought here " Some people in cars just don't see motorcycles. Their brains don't register them. " is the exact thought process I am using. If they see a giant ball of fire it will register
Old Mar 27, 2012 | 03:54 PM
Great bike. I love it. I like that "stopper" The happy trails light does look pretty good for my rear coverage.
In WA state the laws says you must have one light but no more than two. I can't have 3. I don't think adding a small LED is enough extra.
Old Mar 27, 2012 | 03:55 PM
Maybe I should have just asked to show the lights without all the extra.
Ok start over, show me your upgraded lights front and rear and signals.
