RPM at Top Speed
Old Nov 4, 2006 | 02:48 PM
tremor38's Avatar
Default RE: RPM at Top Speed
Cool! Does the vapor have volts indicator?
ORIGINAL: MaverickAus
When I get my Vapor fitted I'll let you know what my top speed is with the 17" and 42 tooth.
Old Nov 4, 2006 | 05:03 PM
a16tony's Avatar
- 13/45 or 14/48=76MPH
thats about right for my bike.
Old Nov 4, 2006 | 05:59 PM
The 14:42 combo @ 8500 RPM = 87 MPH sounds right also.
I use a trail tech vapor calibrated with my GPS and both match each other very well, usually within 1/10th of a MPH. I've never had my bike up to 85 MPH - feels a little squirrely at high speed with my trak master II tires, but it is uncanny how closely RPMs / 100 matches the actual speed with the stock gearing.
Old Nov 5, 2006 | 01:40 AM
tremor38's Avatar
Actually, I used 9000RPM for all of the KLX250 results since that was in the ballpark of what most were reporting at 'terminal velocity.' My D-Tracker probably only got to 8500 due to the 14/39 combo...that and the fact that it's completely stock. The speadsheet I'm using probably doesn't get it down to the nat's azz, but I think it gets pretty close.
Is there a volts readout on the Vapor?
ORIGINAL: Nobrakes
Old Nov 5, 2006 | 01:54 AM
ORIGINAL: tremor38
I don't recall seeing a voltage display on it - that would be handy, though. Not sure why they didn't add one - seems like it would be trivial to incorporate.
kansas-klx
Jul 23, 2024 04:21 AM
09klx
Jun 6, 2010 05:09 AM
rkelley548
Jun 17, 2009 07:43 PM
Raider556
Apr 24, 2007 01:23 AM
shawn_460
Jul 7, 2005 02:26 AM
