Replacing FR sprocket. Lube question.
Old Jul 11, 2012 | 08:20 PM
Malves's Avatar
Default Replacing FR sprocket. Lube question.
Wondering what you guys are using to lube the threads of the output shaft when replacing the FR sprocket.
Need something to be picked up locally. Donīt have time to order online, since my nephew is leaving the US next Friday morning to visit us down here.
Thanx.
Old Jul 11, 2012 | 08:27 PM
I don't believe anything is actually recommended, but I use antiseize on those threads. I've done it on every chain drive bike I've ever owned. I've never had a problem with doing so, and in fact was always able to spin my countershaft nut off with one good hit of the air impact wrench. I've never had it loosen or act up in any negative way when using antiseize. This is over a time span of over 40 years, and I can't remember how many bikes.
Old Jul 11, 2012 | 08:46 PM
ahnh666's Avatar
this is what i use on my bicycles...and, i use the same on my klx250sf... ...i use it on anything threaded or moving...
Old Jul 12, 2012 | 05:35 PM
MaverickAus's Avatar
Never heard of lubing the output shaft in 40 years of riding.
Old Jul 12, 2012 | 06:59 PM
stephenmarklay's Avatar
I don't really see a need either. I just put one on my Ninja 500 and did not. It is a different set up where the sprocket slides onto splines and 8mm bolts hold a retainer clip of sorts. I like that setup.
Old Jul 12, 2012 | 08:07 PM
Malves's Avatar
I am just doing what the service manual calls for.
Old Jul 12, 2012 | 09:51 PM
I also use anti-sieze on the countershaft nut. Any auto parts store should have it.
Old Jul 12, 2012 | 11:27 PM
RimBender's Avatar
Been doing it for years, just what I was taught I guess. I can remember bike that had spline wear problems, maybe that's why it became common practice. I just snug the nut and 1/2 fold the washer for ez sprocket swaps, don't think I have ever torqued it tight? One of theses days I'll buy a fuji lock nut and toss that washer.
Old Jul 14, 2012 | 07:40 PM
MaximusPrime's Avatar
OK, where does one get a fuji nut that big? Found a site selling them for KLR axles, but that doesn't help much.
Brieninsac
Aug 22, 2023 05:13 PM
Malves
May 31, 2012 09:24 PM
Malves
Oct 27, 2011 01:31 PM
Unstop
Ninja 250R
Nov 21, 2008 03:15 AM
navyman
Apr 11, 2006 03:10 AM
