Replacement switchgear?
What switch gear do people upgrade to when the factory stuff is shot? The sun has taken a toll on mine, and since I ground off the nibs for the Pro-Taper bars, it's really hard to keep the cheap plastic factory ones from turning on me. THANKS!
They bite down nicely into the tape and don't come loose or rotate easily.
I was thinking about a turn or two of an old bicycle tube for the plastic to bite into but, the sun damage to the plastic is causing me some grief. I'm a little worried that biting into some tape or rubber is going cause the brittle plastic sides to fail.
Funkdock
Apr 12, 2006 05:56 AM
