Removing Secondary Throttle Blade - Yay or Nay?
Old Jul 15, 2024 | 03:34 PM
Bullfrog12's Avatar
Originally Posted by hobospeed
I'm pretty sure all of the EFI bikes have them so 2018 and onward in NA.
Tim
Thanks
Old Jul 16, 2024 | 12:33 AM
tooter's Avatar
I removed BOTH my secondary throttle plate AND the primary throttle spring as well. Now the ECU has NO CONTROL over the primary throttle at all, neither OPENING or CLOSING. The engine is more responsive both opening the throttle as well as closing the throttle The primary throttle spring holds the throttle plate upen after the throttle is released, for a "soft close", and also makes that manic fast cold idle.
I ride steep canyon roads, so the immediate engine braking is welcome. And the engine cold starts perfectly. It just idles at the regular idle speed instead of racing. The primary spring just comes out with a needle nose pliers (watch where it flies!) It's worth a try. If you don't like it, you can always simply put it back in in a few seconds.
mmurray70
Jul 16, 2024 07:26 PM
nornalup
Jun 8, 2011 03:38 PM
ol guy
Jun 21, 2010 05:31 PM
markturbo
Feb 16, 2007 05:59 AM
kawizx7
Dec 23, 2005 04:31 PM
