Removing Secondary Throttle Blade - Yay or Nay?
Old Oct 8, 2022 | 07:58 PM
Peter Leif Lindvall's Avatar
Nice!
What is the reason for the spring?
Old Oct 9, 2022 | 05:29 PM
tooter's Avatar
Originally Posted by Peter Leif Lindvall
Nice!
Same as all of the other restrictions... emissions.
Old Jan 18, 2023 | 07:45 AM
danklyrides's Avatar
Question
Originally Posted by tooter
I paired the secondary throttle plate delete mod with my primary throttle plate ECU control spring delete mod.
The Ecu delays closing the primary throttle plate which reduces engine braking, and also holds the plate open for that irritating manic fast cold idle. Simply removing that spring frees the primary throttle plate from ALL ECU controls. The engine still cold starts and runs just fine because the cold mixture is still rich, it simply idles at the same 1,500 rpms as when the engine is hot..
Try it, you might like it. If you don't, it's easily reversabie.
I live in a canyon so all the asphalt I ride on is twisted. Having instant deceleration engine braking from an instantly fully closed primary throttle plate is a great help in cornering.
Hi Tooter. Do you have any pictures or descriptions of the process you went through to remove the plate? Did you have to remove the throttle body or the air box?
Thanks!
dankly
Old Jan 18, 2023 | 04:11 PM
tooter's Avatar
Thanks!
dankly
You definitely need to gain access to the back end of the throttlebody however you can in order to get a driver onto the screw which holds on the plate. Naturally this screw has been staked to hold it in so it will resist removal. You want a good sharp properly sized Phillips screwdriver so as to engage the screw head positively and with plenty of downforce so it does NOT strip. You do NOT want to strip that screw. Here's a pic.
Removing the secondary throttle plate gets rid of that irritating 7,000 rpm "dip" in the dyno chart, because the ECU holds the plate halfway open and only opens fully above 7,000 rpms. Here's a dyno run I did testing the custom exhaust before that mod.
This mod also works well paired with the ECU primary throttle plate control spring delete.
Old Jan 18, 2023 | 11:32 PM
greychinos's Avatar
Serious question, when you're accelerating under wide-open throttle, at what RPM do you usually upshift in each gear?
Old Jan 19, 2023 | 05:36 AM
tooter's Avatar
I'm just a regular daily transportation rider so my bike rarely gets full throttle and never hits the redline rev limiter.
Old Jan 19, 2023 | 02:33 PM
bmart's Avatar
I also never go anywhere near full throttle. Don't seem to need it anywhere, on or off road. I usually shift between 5k and 7k.
Old Jan 19, 2023 | 11:04 PM
PineBarrensGuy's Avatar
Maybe not so, new car models are coming out without throttle plates at all as crazy as it sounds. Completely open to atmosphere and controlled by the fuel management system completely. I kind of like the plate but that's progress.
Old Jul 15, 2024 | 01:57 PM
Bullfrog12's Avatar
What was the first year that the KLX250 had the secondary throttle plate?
Thanks
Old Jul 15, 2024 | 03:14 PM
hobospeed's Avatar
Thanks
I'm pretty sure all of the EFI bikes have them so 2018 and onward in NA.
Tim
