Removing Rear Fender Extension
Old Sep 18, 2012 | 03:15 PM
dvarhol's Avatar
Default Removing Rear Fender Extension
I removed the rear fender extension on my 2007 klx250, and unplugged the electrical connection that powers the rear license plate light. Right after I did that, my headlight and rear running light stopped working. Turn signals and brake light works fine thought...could I have caused short or blown a fuse by removing that rear license plate illumination light?
Old Sep 18, 2012 | 03:38 PM
Nope. I have taken mine off. and no issues. You goofed something up.
Old Sep 18, 2012 | 03:59 PM
djchan's Avatar
Ya, I just cut the wire to the plate light, curled it up and left it between the fender and the subframe. All other lights work just fine. Just did it last weekend.
Old Sep 18, 2012 | 04:02 PM
dvarhol's Avatar
okay so knowing that removing the plate light couldn't have caused the headlight/brake light to go, what could I check next? fuses?
Old Sep 18, 2012 | 04:57 PM
It sounds like a blown fuse. Good as place as any to start.
Old Sep 18, 2012 | 06:20 PM
rgoers's Avatar
...might be a safety feature Kawasaki built in, to prevent you from riding at night without the rear beaver-tail...
+1 on checking the fuses.
Old Sep 19, 2012 | 12:36 AM
dvarhol's Avatar
yup you guys were right, blown fuse!
Old Sep 19, 2012 | 12:57 AM
lj-rubi's Avatar
Originally Posted by djchan
Ya, I just cut the wire to the plate light...
I assume there is a positive and a ground. If you cut through both at the same time you would have definitely blown the fuse at that point. Glad you found the problem!
Old Sep 19, 2012 | 02:55 AM
RimBender's Avatar
related topic, if you inadvertently get the high beam/ low beam switch held in the middle position it'll take that same fuse out. Both lights on at the same time draw too much power. Done it a couple times now and threw some spares in the tool kit (and installed a bigger fuse ) your call on that
Old Sep 19, 2012 | 02:41 PM
Welcome to the forums.
