Removing California Smog
Old May 1, 2011 | 06:01 PM
RobG's Avatar
Default Removing California Smog
I found the thread on removing smog... but I haven't seen anything specific to the removal of all the California smog crap.
There are three hoses coming out of the bottom of my gas tank. One appears to be a regular vent. The other two go to what I think is the KCAS check valve. From there, lots of hoses go all around... two go into a Tee in the carb, a couple go to the charcoal canister, and then there's the crankcase line that goes to the airbox.
I'm wondering, do I need to put nipples on the lines out of the gas tank? I know I need to plug the line on the carb, and I know to put a breather on the crankcase at the top of some hose. And I think I seal off the line into the airbox.
What else am I missing? I want to make a list and hit the auto parts store today and get this stuff done.
Thanks!
Rob
Old May 1, 2011 | 10:50 PM
RobG's Avatar
Nevermind. I thought it out and just plugged everything and it seems to be working. I also wired up an accessory relay while I was at it, and a 12v power outlet. I'm also ready for when I get my heated grips.
Rob
Old May 3, 2011 | 04:04 AM
oldfart_newrider's Avatar
Rob
Does it ride any different after removing everything? More power?
Old May 3, 2011 | 03:03 PM
RobG's Avatar
No, it just feels better knowing that garbage isn't on there anymore.
BTW one of the two lines on the tank that I plugged needed to be vented. Discovered that a couple miles from the house when the bike quit. I opened the gas cap and it fired right up, so I knew. Got home, pulled off one plug, nothing. Pulled off the other, and it made a gasping noise. I knew that was the one. Reinstalled the first plug and put a hose on the other one. This won't be a problem once I get an IMS or Acerbis tank.
Rob
Old May 3, 2011 | 03:18 PM
Ranger Ron's Avatar
I think that removing California smog is a great idea.
Just don't send it east to Arizona.
Ron
Old May 4, 2011 | 10:00 PM
TexasFlyer's Avatar
Ron
Why not send to AZ? I just did all the smog removal mods plus dynojet plus fmf pipe to my CA model in AZ. Is there something i need to be aware of?
Old May 4, 2011 | 11:30 PM
Ranger Ron was making a funny. He does not want the smog that is, for instance, around LA to blow over to AZ.
Dan ,,,,,we don't want it in IL either
Old May 5, 2011 | 02:19 PM
linkin5's Avatar
The perks for smog removal are a cleaned up engine area and cooler exhaust temps but not a performance improvment.
Old May 5, 2011 | 03:24 PM
Ranger Ron's Avatar
I have no idea how it happened, but as I was taking my engine apart to do the 351, I noticed the air injection system. After putting it back together I looked closely and it just wasn't there.
Ron
Old May 5, 2011 | 05:57 PM
WhiskeyTF's Avatar
Tampering with emissions equipment is breaking a federal law and carries up to a $2500 fine. But unless you're in an area that does inspections and forget to put it back before you go, you're unlikely to get popped.
