Rear Swiwgarm Maintenance Question
Old Jan 19, 2014 | 04:09 PM
mtbcrossover's Avatar
Default Rear Swiwgarm Maintenance Question
Had the swingarm off to replace the bearings and noticed that there is some side to side play with the linkage. Should there be any play?
Old Jan 19, 2014 | 04:48 PM
GBAUTO's Avatar
If you are talking about being able to slide the pivot pins from side to side then that is normal. The only thing that shouldn't have any perceptible play is radial movement(in line with the ends of the links). When you pull the linkage apart it should be pretty obvious if any of the bearings need replacement.
rkutzner
Dec 24, 2013 05:08 PM
Rruiz
Jul 16, 2010 08:08 AM
gas_sippin_Kawi
Ninja 500R
Oct 25, 2006 08:30 PM
yelnats126
Ninja 250R
Aug 16, 2006 08:08 PM
Jutboy
Mar 26, 2006 03:13 AM
