rear sprocket
Old Mar 23, 2012 | 09:44 PM
ahnh666's Avatar
you might need a new longer chain probably...pretty simple...rear wheel..27mm left bolt...right bolt..use needle nose pliers to bend the pin straight and pull out....22mm to loosen the right bolt....12mm open wrench to loose the small fine adjustment bolt away from the wheel bolt first...loosen that all the way to the head of the bolt....do the same on the other side...take chain off the rear sprocket...wheel comes off...
Originally Posted by Babaloo
I just added at 13T and couldn't tell a difference so Im thinking of adding a 45T or 48T to the rear. Is there a post which explains removal of the rear...
Oct 31, 2006 06:06 PM
Bad Bear
Oct 8, 2006 05:56 AM
dazjr
Aug 17, 2006 05:48 PM
57piper
Jul 17, 2006 11:28 AM
