Rear Brake not engaging
Old May 21, 2011 | 02:53 PM
lawrencecar's Avatar
Default Rear Brake not engaging
No stopping when depress the rear brake pedal (or very little). Is there an adjustment or how to ? Dont see it in the owners manual , Thanks
Old May 22, 2011 | 02:49 AM
TexasKawai's Avatar
There is no adjustment on brakes. You might have gotten an air bubble in the system. You can try to bleed the rear brake and this should take care of the problem. If not you may have to rebuild the master cylinder.
Just had this happen on a friends sport bike and a simple bleed did the trick.
Old May 22, 2011 | 02:51 AM
akarob's Avatar
Bleeding the brakes is certainly the first step. It's actually part of regular maintenance too.
Old May 22, 2011 | 11:22 AM
maninthesea's Avatar
Just want to clarify is the rear brake not working as well as it used to or are you commenting on its considerably lower stopping power than the front.
Old May 22, 2011 | 03:44 PM
Here is another possibility. Have you recently oiled the chain with a spray lube? Its easy to over spray and get it over on the brakes.
Old May 22, 2011 | 11:19 PM
anyone have a how to on this ?
Old May 22, 2011 | 11:30 PM
Sakiman289's Avatar
Get yourself a hydraulic bleeder, makes it SO much easier. Tusk makes one for $10.
Old May 23, 2011 | 01:32 AM
Sakiman289's Avatar
I modified my bleeder with a old Mt. Dew bottle (seem to be plenty of those around here) I drilled a hole in the cap the same size as the tubing, slid the tube through the cap and wrapped it with electrical tape. Works great, truly makes bleeding brakes a one man job, and you don't lose any fluid.
Attached Thumbnails Rear Brake not engaging-2011-05-22_20-05-01_476.jpg   Rear Brake not engaging-2011-05-22_20-06-24_902.jpg
Old May 23, 2011 | 03:50 PM
Thanks just ordered one from rocky mountain. Nice instructions, seems straight forward:
http://www.rockymountainatvmc.com/do...%20Bleeder.pdf
Old May 26, 2011 | 05:49 PM
rgoers's Avatar
Originally Posted by TexasKawai
There is no adjustment on brakes. ...
My '09 has an adjuster for brake pedal position, which in turn provides more leverage (pressure) at the master cylinder. If adjustments don't help -
I'd lift the rear, and look it over carefully. Are the pistons coming out when you depress the brake pedal? Is there oil on the rotor (as someone else suggested)? Pads worn? Pads correct pads? Look it over carefully...
thekeeper199
Sep 27, 2014 09:22 PM
ttakata73
Aug 27, 2010 03:29 PM
kronus
Jun 27, 2008 01:27 AM
ntloser
Oct 23, 2006 02:07 PM
funtoos
Mar 28, 2006 09:04 PM
