RE: will a 98 klx 300 exhaust fit an 06
Old May 5, 2007 | 03:58 PM
doitinthewoods's Avatar
Default RE: will a 98 klx 300 exhaust fit an 06
looking at one just wondering before I bid
Old May 5, 2007 | 04:01 PM
bryantjt's Avatar
If you get both the headpipe and muffler, yes you can use it but you will have to rejet to make the bike run properly.
Old May 6, 2007 | 06:18 AM
mmatz's Avatar
Just got through bolting up the KLX300 header and exhaust to my 2006 KLX250S. Perfect fit and the noise level is low enough that you can leave for work early and not **** off the neighbors.
Old May 6, 2007 | 02:31 PM
bryantjt's Avatar
Did you leave the baffle in or pull it? By baffle I mean the plate with 2 screws on the back of the can. My muffler didn't come with one and it makes my ears ring when I go over a steel deck bridge, so I made my own baffle and a downturn and interchange them as noise level requires.
Old May 6, 2007 | 04:02 PM
tremor38's Avatar
Ok, If you won't say,I will. He means the 'buttplug' as 300R riders colorfully refer to it as.
ORIGINAL: bryantjt
Old May 6, 2007 | 05:32 PM
bryantjt's Avatar
It had a butt plug at one time, now it appears the colon turned inside out........[sm=icon_rofl.gif]
Old May 6, 2007 | 06:12 PM
mmatz's Avatar
ORIGINAL: bryantjt
100% stock 1995 KLX300R exhaust with baffle. It is quiet to the point that a little more Deep Throat would be OK. But butt plugs?
Old May 6, 2007 | 08:21 PM
bryantjt's Avatar
Mmatz, could you measure the opening on that rear plate? The baffle I made is fairly quiet but its too restrictive, makes the bike vibrate more and loses alot of low end. BTW, try running it with the cap off for a few miles offroad, you might be surprised at the difference.
Savage
Jun 27, 2012 04:02 AM
2k1w=no$
Jan 6, 2009 01:00 AM
toothman32
Jan 27, 2008 03:12 AM
kawi boy
Oct 4, 2007 05:45 AM
scat
Jun 5, 2006 04:01 AM
