To re-jet or not ?
Old 02-02-2009, 09:10 AM
OzKLX250s's Avatar
Default To re-jet or not ?
G'day from another Aussie.
I purchased a new 09 KLX250S a few weeks ago, have now done 1500kms
Current mods
- carby slide holes filled
- snorkel removed
- Staintune muffler (original header pipe)
- Retnal bars, grips, barkbusters, leaver ***** cut off.
To be done soon;
- 13 tooth drive sprocket (dealer back ordered)
- Rear fender trim
My question:
I read most people are re-jetting the carb after opening the air in/out
I am still running original jets, I have been checking the spark plug and it looks pefect. I do get slight poping when backing off from high revs under load, however I am guessing the fuel air ratio is pretty good.
Should I re-jet ? is there some thing I am missing ?
Old 02-02-2009, 10:15 AM
WestOzKLX's Avatar
No mate. The Oz bikes get a #132 main and a #35 pilot standard. Plenty if you only removed the snorkel. If you fit a high flow air filter and take the lid off the airbox you can rock #135 or a #138 main jet. If you do go with the bigger main jet I recommend raising the stock needle 1.5mm with a spacer.
My recommendations come from my Oz spec 07. It could well be a shot in the dark for the 09 model.
Old 02-02-2009, 10:35 AM
MaverickAus's Avatar
My question:
G'day mate welcome to KF.
Mine was stock and ran fine with no mods at all, like yours a little popping when rolling off the throttle. I still have the air box lid and snorkle on. Only thing was it could be hard to start if left sitting for a week or more. As westie said this is an american site and their carbs are setup different to ours.
Cheers
p.s. mine is an 06
Old 02-02-2009, 11:19 AM
buffalony's Avatar
DO the Austrailian bikes have the ACR on them? If they do then take it off. That will solve your problem with the popping noise.
Old 02-02-2009, 11:49 AM
WestOzKLX's Avatar
Na! we don't get that s*#t.
Old 02-02-2009, 12:24 PM
tremor38's Avatar
I'm pretty sure you meant to say 'KACS' rather than 'ACR.'
'ACR' is the Auto Compression Release on the end of the exhaust cam. It only works during engine starts.
Old 02-02-2009, 12:37 PM
WestOzKLX's Avatar
My bad. I thought it was a reference to the "smog" stuff USA bikes get. DOH!
Old 02-02-2009, 08:50 PM
buffalony's Avatar
You are right Tremor! That is what I meant
Old 02-02-2009, 10:39 PM
WestOzKLX's Avatar
Then yes we do get the KACR.
Old 02-03-2009, 12:56 AM
OzKLX250s's Avatar
Cheers Guys, I will leave the carb as is for now.
Quick Reply: To re-jet or not ?
