To re-jet or not ?
G'day from another Aussie.
I purchased a new 09 KLX250S a few weeks ago, have now done 1500kms Current mods - carby slide holes filled - snorkel removed - Staintune muffler (original header pipe) - Retnal bars, grips, barkbusters, leaver balls cut off. To be done soon; - 13 tooth drive sprocket (dealer back ordered) - Rear fender trim My question: I read most people are re-jetting the carb after opening the air in/out I am still running original jets, I have been checking the spark plug and it looks pefect. I do get slight poping when backing off from high revs under load, however I am guessing the fuel air ratio is pretty good. Should I re-jet ? is there some thing I am missing ? |
No mate. The Oz bikes get a #132 main and a #35 pilot standard. Plenty if you only removed the snorkel. If you fit a high flow air filter and take the lid off the airbox you can rock #135 or a #138 main jet. If you do go with the bigger main jet I recommend raising the stock needle 1.5mm with a spacer.
My recommendations come from my Oz spec 07. It could well be a shot in the dark for the 09 model. |
Originally Posted by OzKLX250s
(Post 354082)
My question: I read most people are re-jetting the carb after opening the air in/out I am still running original jets, I have been checking the spark plug and it looks pefect. I do get slight poping when backing off from high revs under load, however I am guessing the fuel air ratio is pretty good. Should I re-jet ? is there some thing I am missing ? Mine was stock and ran fine with no mods at all, like yours a little popping when rolling off the throttle. I still have the air box lid and snorkle on. Only thing was it could be hard to start if left sitting for a week or more. As westie said this is an american site and their carbs are setup different to ours. Cheers p.s. mine is an 06 |
DO the Austrailian bikes have the ACR on them? If they do then take it off. That will solve your problem with the popping noise.
Na! we don't get that s*#t.
Originally Posted by buffalony
(Post 354094)
'ACR' is the Auto Compression Release on the end of the exhaust cam. It only works during engine starts. ;) |
My bad. I thought it was a reference to the "smog" stuff USA bikes get. DOH!
You are right Tremor! That is what I meant
Then yes we do get the KACR.
Cheers Guys, I will leave the carb as is for now.
