Raising Handlebars on '09 KLX250s
Old May 29, 2010 | 07:51 PM
HarBro's Avatar
Default Raising Handlebars on '09 KLX250s
I'm 6'5" and trying to raise handlebars by 2-3". Is it possible to put in a riser bar? Is there enough cable length to allow that? Is there a different handle bar design that would help?
If anyone has done this before I could sure use some advice.
Old May 29, 2010 | 09:56 PM
Blueraven's Avatar
Please do a search, this topic has been covered many times, as recently as last week.
Old May 29, 2010 | 10:03 PM
punkenduro09's Avatar
he forgot to add welcome to the forum.
decide to help you out cus your new, but the search button is your friend for most topics.
https://www.kawasakiforums.com/forum...earchid=198811
Old May 30, 2010 | 01:46 AM
HarBro's Avatar
Default Thanks
I'm new to the forum and new to dirt bikes, so thanks for the tips. I'll keep searching the previous posting.
Not seeing any info on how much cable length will allow increasing the bar height.
Old May 30, 2010 | 02:18 AM
MaverickAus's Avatar
Can't help with the 09, my 06 has 20mm risers and no problems with cable length
Old May 30, 2010 | 03:46 AM
Newblud1775's Avatar
I just put a Renthal Raptor Bend Bar on my 09 and the throttle had to be placed around 3/8" inward on the bar so as to not bind up when turning the handlebars all the way. I'm 6'4" so I wanted something higher, too. I tried risers from twistedthrottle.com before buying new bars but, the cables just were'nt long enough.
Old May 30, 2010 | 05:07 AM
kx bends are the highest you can go with stock cables. with you height, i would recommend my set up. 3/4th risers, tusk atv bends (big bars), and motion pro clutch cable. the throttles will be close, but it will work. i like my bars pretty high cus i stand a lot, but it should be just right for you.
Old May 30, 2010 | 11:57 AM
armycopter's Avatar
I've got the KX high bend and my clutch cable is maxed out. You can't go any higher with the stock cable.
Old Jun 6, 2010 | 01:03 AM
HarBro's Avatar
Forward riser bars have been recommended to me as they move the handlebars 1.5" up and 1.375" forward. They seem to only work for 7/8" bars. Has anyone ever tried these on an '09 KLX 250? This would seem to provide the height and not bind the cables.
See them at www.barrisersonline.com
DirtSurfer
Mar 4, 2007 03:12 PM
klxstiffler
Jan 7, 2007 12:55 PM
queenpdog
Oct 11, 2006 03:52 AM
kevlarian
Ninja 500R
Sep 22, 2006 04:41 AM
bkyee
Ninja 500R
Sep 4, 2006 11:17 AM
