Raising gear ratio ???
Old Jun 13, 2010 | 08:08 AM
BP88's Avatar
Default Raising gear ratio ???
Okay, I've got the stock 14T front and 42T rear. I swapped over to 17" SM wheels and was wondering what I would need to do in order to get my bike back as close to stock gearing as possible. Should I get a 15T or 16T for the front? Or should I drop a few teeth in the rear? I'd like to be able to use the stock chain but I wouldn't mind buying a new chain if I really had to.
This bike is now my main mode of transportation since my Jeep eats up too much gas and I work far from home; therefore, I must ride it on the freeway and the low gear ratio isn't too much fun on Interstate 5.
Old Jun 13, 2010 | 07:08 PM
BP88's Avatar
Anyone know?
Old Jun 13, 2010 | 11:59 PM
MaverickAus's Avatar
The D-Tracker runs 14/39. I assume that would bring it back to approx the same revs vs speed. You could try a 15 front which would get you around the same affect. Cheaper and you should be able to use the OEM chain
Old Jun 15, 2010 | 05:38 AM
BP88's Avatar
Thanks a bunch Maverick.
Any other suggestions?
Old Jun 16, 2010 | 09:44 AM
Not sure what else you want to know?
some_change
Aug 19, 2010 03:15 PM
minime0616
Ninja 500R
Oct 13, 2007 10:16 PM
neilaction
Oct 5, 2006 04:03 PM
bigbeardan
Sep 13, 2005 05:11 AM
ZX12Rider
Aug 2, 2005 03:31 PM
