radiator question
Old Feb 15, 2007 | 04:51 AM
kawiridr04's Avatar
Default radiator question
when i was on some trails one day i was riding up a leafy muddy hill and the bike wouldnt go anywhere so i got off it and tryed popping the clutch and pushing it up the hill and i was revving it pretty good. then it shut off and a fan turned on somewhere near the radiator. just wondering if this is caused from giving it gas and not going anywhere and not getting air into the bike or what?
Old Feb 15, 2007 | 04:57 AM
bryantjt's Avatar
Default RE: radiator question
Did the bike stall out or while you were revving it did it just quit? Did the red overheat light come on on the dash? I've had the fan come on a couple times on my bike while working my way through a nasty rock filled mudhole in the summer, the fan coming on is normal, its to help prevent it completely overheating.
Old Feb 15, 2007 | 04:59 AM
kawiridr04's Avatar
ok i was just making sure it was natural for ut to do that. i didnt look to see if the light came on i was too busy holding the bike up so i didnt get crushed. i guess it helps to have some tread on your tires! ha
Old Feb 15, 2007 | 09:25 AM
The only time my fan came on is on slow trails in first gear. It startled me the first time it came on, then I was like oh cool.
Old Feb 15, 2007 | 12:15 PM
My fan has never come on..... havent seen the little overheat light either... maybe cause i dont go slow.....
Old Feb 15, 2007 | 02:42 PM
cwgoff's Avatar
My fan has come on once or twice, always in an instance similar to that described by kawiridr04. Since installing my KLX300 tank, though, I still haven't gotten around to installing the dual-fan replacement for the stock unit. I haven't done much low-speed technical trail work, so I haven't needed it. The only single-track stuff I have done since then was at TdAII, and that was all at reasonable speeds.
Pedrowitus
Jun 7, 2013 09:10 PM
punkenduro09
Mar 8, 2009 05:19 AM
kaboom133
Ninja ZX-9R
May 6, 2007 01:40 AM
importmonkey
Nov 8, 2005 10:27 PM
eztalking
Aug 27, 2005 03:59 AM
