Quick tire size question
They will be darn close. Most manufacturers have sites where they have the actual aired up size listed. Here are a couple that I hope are still good. You have to do a minor amount of digging from there.
Shinko - Welcome to the Korea official homepage of Shinko Tires
IRC - IRC TIRE world wide top page
Bridgestone - Motorcycle-Karttires I recommend the Spitfire. At the lower right there is a spot for details or something, that is where the specs are. The Spitfire S15 is a dual compound tire found frequently on vintage bikes and builds. We sold a ton of them when I worked the bike shop in the 80s. Still strong seller in general.
Dunlop - Dunlop Tire Catalog I forget where it's at on the Dunlop site.
Duro - http://www.durotire.com/products.php has a relatively decent tire. A harder rider might want something a bit more sticky.
As for the size of the tires, the general rule is the width may vary up to 5mm wider or narrower, that's nearly 1/2 inch, so again look on the sites. The profile may vary a few millimeters but is a % of the width, thus the 90% of a 110mm would put the profile at 99mm with some allowance, but probably not a plus/minus 5. It should be tighter than that.
