Quick and Cheap L/P Mod
Old Nov 18, 2007 | 08:23 PM
klx250s_rider's Avatar
Default Quick and Cheap L/P Mod
I wanted to raise the license plate without spending any money and still make it look stock - how's this? I removed the license plate and bracket, reversed the bracket, removed the reflector, drilled two 3/8" holes and bolted the whole thing back together. It raised the license plate by almost four inches - maybe not enough for KawiKathy, but it works for me
Old Nov 18, 2007 | 08:26 PM
dirt_beaver's Avatar
Default RE: Quick and Cheap Mod
Looks good. I did the same thing to my bike, but cut the black plastic up a little. (cut off from right above where the old plate use to mount) ThenI added some heat to the edges and bottomto give it a more finished look. I'll take some pics of it later.
Old Nov 18, 2007 | 08:35 PM
kawikathy's Avatar
Default RE: Quick and Cheap L/P Mod
You're right "almost four inches" just doesn't work for us women, now if it was 7 or 8 inches....
[sm=happybounce.gif]
Old Nov 18, 2007 | 08:38 PM
bryantjt's Avatar
I had to do something similar when my upper plate mounts ripped through, damn knobbies. I ended up leaving the brackets alone and just drilling 2 holes in the plate in the blank white outside the numbers. I wanted to do the same thing you did but the top corners of my plate are missing.
Old Nov 18, 2007 | 08:45 PM
Nice ride today KC! One of these days us guys will keep up with your crazy a*s single track riding.
Old Nov 18, 2007 | 08:47 PM
kawikathy's Avatar
It was just beautiful out there, it must have got up to 85 degrees today. Oh and thanks for buying the beers afterwards!!
Old Nov 18, 2007 | 08:48 PM
Josh, let's see a picture of it.
Old Nov 18, 2007 | 08:56 PM
bryantjt's Avatar
It's dark in the garage so here's the only one I have. You can see how I had to trim the "ears" on the plate, I figured it would be best to remove them instead of letting it rip farther.
Old Nov 18, 2007 | 09:00 PM
Looks fine! I do like your black seat cover too! I bought one a while back and still haven't put in on.
Old Nov 18, 2007 | 09:02 PM
kawikathy's Avatar
I like it too-it tones down all that green and balances out the appearance.
