Questions on proper chain maintenance
WD-40 has graphite in it... this could have good deal to do with the wonder chain lol.
Edit: Ppl are going to argue this too and I know it, but WD-40 is like %10 inert ingredients... I just know it has something similar in it, I don't care what they say or profess... me and my friend who is a chem. eng seems to agree to some degree.
OK now do the test with wax lube, You can ride all year so it will not take too long to do the 35,990 miles?
There is no control on the test. The chain is lubed on the inside, what ever you do to the outside other than keep it relatively clean is meaningless.
I use a silicon spray about 1/month just before a ride.
But then...chain lube threads aren't much different from oil threads in the kind of fervor they bring out.
This was a good test: Chain O-ring WD-40 exposure effects study and results - ADVrider
Gasoline and carb cleaner bad...
That PDF is talking about an o-ring chain. It would make no difference on stretch as the o-rings are containing the grease from the factory and the WD-40 is only lubing the exterior surfaces. It would be more interesting to see a comparison of wear on the sprockets and chain .... er... round bits. I want to say rollers but you know what part I mean, the part that hits the sprockets.
