Question on front tire size
Old Aug 26, 2012 | 12:15 AM
Brieninsac's Avatar
I went to Cycle Gear today and they happened to have the Scorpions in stock, even though the front is slightly bigger (90/90-21) then what I orginally wanted (80/90-21). Fortunately they matched the online prices I got and mounted / balanced them for $20 each. I'll post pics when I get the wheels back on the bike.
Old Aug 26, 2012 | 01:11 AM
RimBender's Avatar
hey, the 90 profile may make your speed a bit more accurate?
I run the bigger size front for the extra cush on trail junk, My friends don't like them thinking they try to climb out of ruts, never had a problem with it.
For the street you can air em a bit higher for the same feel as the 80 profile.
Old Aug 26, 2012 | 01:26 AM
Brieninsac's Avatar
Question on air pressure. The tire says 38 psi but the manual says 22 psi for the bike. I mainly do street, should I go with higher pressure?
Old Aug 26, 2012 | 02:42 AM
ol'klx-er's Avatar
No, the sidewall states the max the tire is rated for. The manual states the correct pressure for the tire on the bike, 22 lbs. I think the bike would be dangerous with 38 lbs in the tires.
Old Aug 26, 2012 | 04:26 AM
Brieninsac's Avatar
That makes sense, obviously the tire is going to be rated for heavier bikes thus needing more psi. I'll set mine to 22.
Unfortunately, I couldn't both tires on tonight since the installer put the front tire on backwards. My fault for not checking before I left. So tomorrow I'll take it back and have him switch it around. Then it's test ride time!
Old Aug 27, 2012 | 01:00 AM
Brieninsac's Avatar
I got both tires on today. I really like the look. It still looks like a dirt bike but with better street tires. It'll take a week to break them in before I can get real feel for them. I did notice the smoother ride on my test run so that's good.
Attached Thumbnails Question on front tire size-photo-1.jpg   Question on front tire size-photo-2.jpg   Question on front tire size-photo-3.jpg   Question on front tire size-photo-4.jpg
Old Aug 27, 2012 | 01:06 AM
azdeuce's Avatar
Just like mine...what size did you put on the rear?
You will like them..I do
Old Aug 27, 2012 | 02:31 AM
Brieninsac's Avatar
I got a 90/90-21 and 120/80-18. I think I'll like them too.
Old Aug 27, 2012 | 03:49 PM
ahnh666's Avatar
i like it..have you done any freeway test rides?...i'm very curious to high speed stability....especially cruising 70 mph to 80 mph...
Old Aug 27, 2012 | 04:04 PM
Brieninsac's Avatar
No freeway yet. I'm looking forward to seeing how it handles at higher speeds too.
