Problem with throttle response
Old May 13, 2022 | 04:45 AM
Schniebs's Avatar
Lightbulb Problem with throttle response
Hey guys,
I am new to this forum and couldn't find a related threat to my issue. If someone has already tackled this problem, apologies in advance, please sent the link and I'll have a look through there.
My Kawasaki KLX 2010 started making some weird clanking noises so me and my buddy suspected it to be the cam chain tensioner.
After removing the old Cam chain tensioner and finding it had a piece missing, I assumed the worst, that it is somewhere inside the engine causing chaos.
So we pulled the whole bike and engine apart to check for damage and I figured while we have it apart might as well do a full service. Including installing
1. Krieger Cam Chain Tensioner
2. FMF Q4 Slip on with Megabomb header
3. Hi-Flow air filter
4. Hi-Flow Oil Filter
5. Iridium Spark Plugs
6. Chain, Sprockets, Grips etc. non engine related
Unfortunately I live on a small island in Thailand and delivery for the parts took several months, meanwhile the engine was covered but not sealed sitting in the humid conditions.
After recleaning everything and installing the new parts, it was time to start the engine but unfortunately it has trouble running.
I uploaded a video of the start up. For the bike to run you have to open the throttle when pressing the e starter, it idles a few moments but as soon as you open the throttle a second time it dies.
I suspected it might be a bad fuel mixture, so took the EFI apart and cleaned the jet but without any success.
Here is a link to my Google Drive Folder with a pic of the broken Cam Chain Tensioner and 3 videos of the bike start up
https://drive.google.com/drive/folde...gu?usp=sharing
I appreciate any help or advice in advance.
Cheers,
Lukas
Old May 13, 2022 | 03:36 PM
durielk's Avatar
What does it mean you "cleaned the jet without success"? Did you clean it or not? Did you gap your plugs? Sounds like a fuel issue, I run a carb, so can't help you there.
Old May 18, 2022 | 12:38 PM
Schniebs's Avatar
Sorry, that was a bad explanation on my part.
I cleaned the EFI but it did not fix the issue.
We did try 2 different spark plugs (both Iridium).
I also think it might be a problem with fuel or air delivery but not sure how to tackle the problem.
Thanks.
linuspa
Aug 24, 2015 08:56 PM
Illking
Oct 5, 2011 11:52 PM
glorp
Oct 3, 2010 04:48 PM
jeffs99vulcan
800, 800 Classic & 800 Drifter
Jul 29, 2008 03:28 PM
