Primer Bulb Help
I've had enough of the hard starts with this bike. I've done enrichment jet drilling & jetted....i pull the choke out slowly to start, etc. However, I am not going to hit the shut off valve and run it until it stops... redicilious. Also if my battery is down and im out in the adriondacks for the weekend then I am not going to get her going...no kick start yet...
if i do primer bulb... goes it go directly into the carb where the existing line is... ive seen it different on other carbs where the primer bulb lines goes dirctly into the top of the carb? could i do a tee and have a line drop into the top of the carb where i pulled off all that smog crap?
evil636
May 25, 2006 05:41 AM
