Prevent Fork Guard From Disconnecting While Braking?
Old Apr 18, 2015 | 04:33 PM
canehdian_guy's Avatar
Default Prevent Fork Guard From Disconnecting While Braking?
Hey everyone,
I have a 2006 klx250s with a stainless steel brake line. While braking the line flexes and pops the left fork guard out. I've tried a few things with no success.
Has anyone encountered this problem and found a solution?
Thanks a lot,
Canehdian
Old Apr 18, 2015 | 04:55 PM
ol'klx-er's Avatar
Is the line binding higher up causing it to flex down lower?
Old Apr 18, 2015 | 05:24 PM
neonarc's Avatar
I had my normal line get block by the clutch line or the headlight switch wires at the handlebar while braking due to incorrect routing. With an SS line blocked by something at the handlebar maybe it could cause your issue.
Old Apr 18, 2015 | 08:27 PM
Thanks guys. I'll check that out. Really appreciate the help.
Bas2thesem
Mar 31, 2008 03:48 PM
xrider
Aug 2, 2006 06:11 AM
taystyl
May 20, 2006 09:19 AM
MoserFtWayne
Apr 21, 2006 04:20 AM
MoserFtWayne
500 LTD
Apr 20, 2006 05:16 PM
